Question about Garden
Motor running rough on 120 John Deere excavator
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
  • 54 Answers
SOURCE: mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Posted on Apr 28, 2010
Fuse panel location for a 1999 200LC John Deere excavator??
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Dec 17, 2016 | John Deere Garden
How to remove a rotary manifold from a John Deere 35C ZTS mini excavator
John Deere
Jul 10, 2016 | Mini Cars & Trucks
How do I change the controls on a John Deere 200 excavator to Caterpillar controls?
talk with a hydraulic engineering shop to find the problems associated with changing the valve bodies over
Nov 06, 2015 | John Deere Garden
Left track on a 120 excavator wont turn when backing up
Check your hydraulic valve that control rear movement.
Mar 10, 2014 | John Deere Garden
What is the smallest john deere excavator?
the John Deere 17D is the most compact, it weighs just over 4000 lbs.
Jan 13, 2013 | Heavy Machinery
What is john deere's largest excavator?
The largest John Deere excavator is the 870G LC, at 40-90 metric tons
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
