Question about Koiiler XM-60 Car Audio Amplifier
I have a xm6660.... yellow light...
My amp comes on for maybe 2 seconds and the yellow light that says thermal comes on and goes off. I dont get any sound. This anp is on my highs, but I dont get any sound out of the amp on my subs either..
    Genius:
  • 1,139 Answers
There are some things I want you to check, 1) Make sure your ground is good and I mean very good, 0 ohms resistance to the negative battery terminal 2) Make sure that your AMP is grounded to that ground point you checked in step 1. 3) Make sure that your power supply B+ wire is one continuous run no taps or spliced connections. 4) Your speakers and woofers are all properly impedance matched to your amplifier (if your amp is 8 ohms then your combined speakers impedance must be 8 ohms total). 5) voltage regulation to amplifier is good. 6) Check all connections and ground points again After these items are done power on your unit and then see if the problem happens again, if it does the issue is inside of the unit, one of the internal components has gone bad and you will need a schematic, a multimeter, and an audio tracer to work on the AMP with.
Posted on Sep 10, 2007
6ya staff
SOURCE:
07 Lincoln Navigator drivers heated seat lights come on for a few seconds and then goes out, passengers heated seat works fine. No sign of damage on connectors on control module"
The heater element maybe burnt . At the control module connector pin's H & G . yellow with blue trace wire And blue with a orange trace wire , use a ohm meter an check continuity between these two wires .
Oct 09, 2017 | Lincoln Cars & Trucks
Hi ive just turned my ps3 on it stopped and went off now it wont play just got a red light when pushed it flashes green and blue the goes red when pushed again it flashes red help
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
When I turn on my Playstation 3, a green light stays on and then the fan goes into "Turbo Mode" for about 30 seconds, the Playstation 3 beeps 3 times and the green light blinks. -No yellow light appears.
have you ever had the playstation taken apart? Maybe you need to replace the Thermal past on the processors. It is due to an overheating problem. I have one right now that does that.
PS3 Power problem. Green led comes on for a second, Beeps 3 times, then goes to yellow. Then starts blinking red.
your ps3 is DEAD man, if you have the warranty send it back to SONY if not pay SONY $150 to fix it for you, if you dont want to do that and you want to try it yourself then do i what i did on oct 13, last night one hour and a half, YLOD means Yellow Light Of DEATH
watch this youtube video, I did it it works follow exactly as he does,
you will need
heat gun ($15-$150+) get one that goes to at least 350degrees F
sivler thermal compound, and some type of card if the compunt doesnt come with a wipe thing,
the proper screwdrivers and then just watch and follow in order
he will show you how to disamble and reasemble the ps3
http://www.youtube.com/watch?v=U70SgRDVcBo
then just watch the rest they are linked to this link
Oct 13, 2009 | Sony Playstation 3 (PS3) Console
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Disc stuck and then Ps3 system when turned on goes from green to yellow then blinking red
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
May 06, 2009 | Video Game Consoles & Games
Amp cuts out
Check your ground wire that's more than likely the problem.Try grounding it in a different spot make sure your ground is a paint and dirt free surface also make sure its directly metal to metal.
Nov 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
Xm6660
It sounds like you may have a power-supply problem. You need to measure the DC voltage across the B+ and ground terminals of the amp. If it doesn't remain near 12v when the amp is on, you need to determine why the voltage is dropping. It could be due to a defective fuse or a corroded connection at the battery.
Aug 29, 2007 | Koiiler XM-60 Car Audio Amplifier
Koiiler XM-60 Car Audio Amplifier Logo
89 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
