Question about Acer Computers & Internet
Yellow screen start laptop yellow dispay showing
  • Acer Master
  • 27,725 Answers
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Posted on Jul 23, 2013
Samsung 5c512 will not display
Ok, the screen is out but... If the laptop has VGA connector you can connect an external monitor and if the laptop recognizes it maybe you can know if the motherboard is working. Good luck.
Apr 04, 2014 | Samsung Rc512 Intel Motherboard...
Display adapters
You need to download the video drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jul 30, 2010 | HP Compaq Presario V2000 Notebook
Will not load past starting screen (HP logo)
maybe is hard disk problem, try boot from cd.(check for any errors dispayed)
Jul 15, 2010 | HP Compaq nc6220 Notebook
I have a hpdv6000 series laptop and recently it
Hi:
I believe that your LCD panel is the problem, but you should verify that you have good video, by toggling to an external monitor to check your output. If it dispays good, you have an LCD problem.
Nov 10, 2009 | HP Computers & Internet
Hp dv9000 screen is dim can only see shadows works fine with external monitor. have replace dispay panel and inverter board still have same problem
go to the power options on the right hand side of the start bar/task bar where it shows the battery level
and the double click it and select high performance
and if that doesent work go to control panel and go to display settings
Nov 01, 2009 | HP Pavilion dv9000z Notebook
When I start crystal webcam error is Camera is busy
It might be the driver problem. Have you checked the device manager? It there any red or yellow alert in it? Feel free to visit digitalsupporttech for getting help.
Aug 19, 2009 | Acer Aspire 5720-6661 Notebook PC
Hp laptop is has docking station connected to acer monitor. The acer monitor has the desktop background but does not show desktop icons. How do I get the icons to show on acer monitor
you will probably find that you have set the screens to run side by side, do a check by clicking the identify monitors, icons will be normaly on the left screen, check the dispay settings and you probably want to set the monitors so they both are showing the same screen at the same time.
good luck.
Jun 30, 2009 | Acer AL2016W 20" LCD Monitor
Help with screen problems?
you have only the one chance to fix this problem because the dispaly is failing, open the latop, disconnect the dispay plug and reconnect it, if its still the same don't worry, all you have to do is connect an external monitor to the laptop if you need your files straight away, then look at having the inverter repaired on the laptop display
Nov 14, 2008 | Dell Latitude D600 Notebook
Yellow stripe
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
12
Aug 29, 2008 | Acer Aspire 1642WLMi Notebook
Computers & Internet Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
