Canon mx922 will not print anything. Brand new out of box. Will not even print akignment. Yes cartridges are new and in properly.
2 Suggested Answers
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
How to use the canon mx922 printer
It is best to read the manual which is available here. Basically you connect it to your home network, install the cartridges, remove packing pieces, and start printing.
PIXMA MX922
Mar 11, 2018 | Canon Office Equipment & Supplies
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Canon MX922 printer: cyan was okay after installing new cartridge, but quit printing blue after a few days. Multiple deep cleanings were no help. Can print head be removed?
You better buy a new cartridge, or you could fix that open the cartridge on your printer device.remove the cartridge and broom with a Kleenex.If you need the driverpleasehere Canon PIXMA MX922
Mar 20, 2017 | Canon Pixma MX922
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
Why will my cannon mx922 not allow me to copy black image when yellow cartridge is empty?
Most inkjet printers, including your Canon, won't print anything if any of the carts are empty. They are designed that way.
May 21, 2016 | Cannon Office Equipment & Supplies
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
Canon PIXMA MX920 error code C000
After market units do not send the proper signal as factory cartridges so put the AfterMarket ReMan back in, Un-Plug the unit for 3 minutes . plug it back in and maybe the computer will accept the reman, just will not show "quantity".
Oct 03, 2014 | Canon Pixma MX922
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
148 people viewed this question
k24674
jasbo
jasbo
