Question about Health & Beauty
Kawasaki bayou 300 2x4
Bike was running fine and now won't start. Tries too on electric but won't kick over...
  • 160 Answers
SOURCE: What are the Torque Specs for a Kawasaki Bayou 350 ATV?
which specs do you need engine ?
Posted on Nov 12, 2008
  • 3567 Answers
SOURCE: kawasaki 300 bayou won't rev up.
No guarantees but try this. Pull the slide from the throat of the carb. Now move the clip on the jet needle down one notch. This will richen the low end mix. Two notches may be needed but do one notch at the start.
Posted on Apr 30, 2009
  • 6 Answers
SOURCE: kawasaki bayou 400 stalls and wont start
The Choke may be stuck or left on.
Posted on Jun 03, 2009
  • 3567 Answers
SOURCE: i have a kawasaki 125 dirt bike it gets fule and
Bottom line is it needs some attention. Remove the tank and flush out the rust, water and any trash in it. Remove the fuel valve assembly from the tank and clean the wire mesh filter screen. Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then thoroughly clean and replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road. Please top rate this answer.
Posted on Jun 28, 2009
bunnydawg
  • 5158 Answers
SOURCE: I have a 88' Kawasaki Bayou 300. It will start
buy a bottle of gasline anti-freeze. it will absorb any water in your fuel. add a half a bottle now and a half next time you fill the tank. should improve the operation of the engine
Posted on Jul 13, 2010
87 bayou has oil like fluid coming out of the pull start and push start won't crank the engine.
the shaft seal is bad behind the pull start and leaking oil into your stater which is why you arent getting any spark for it to crank
Apr 19, 2012 | 2004 kawasaki KX 250 F
2002 kia spectra automatic - sometimes won't start when key is turned, all electrical systems go on but nothing to the starter. After several tries it miraculously starts but sometimes can set for a...
check your battery sometimes it will have enough for lights put not kick in starter then check alternator take to auto zone when running the will test free
Oct 17, 2011 | 2002 Kia Spectra
Jul 13, 2010 | kawasaki Full Suspension Mountain Bike Men
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
My kawasaki 400 bayou runs but doesnt have enough power that it u
I found all spark plugs do not work well in the Bayou, especially NGK....try a champiion spark plug..it may fix the problem.
My Bayou use to stall all the time with the NGK spark plug, but runs good with the Champion spark plug.
May 10, 2009 | kawasaki Full Suspension Mountain Bike Men
No spark wont start
Hey i had a similar problem a liitle while ago on my yamaha,i disconnected the kill switch wire then i had spark(faulty kill switch)
Woth a try,cheers, Alan.
Jan 12, 2009 | kawasaki Full Suspension Mountain Bike Men
Kawasaki bayou 4x4 using engine oil alot of smoke from exhaust
if it is using oil, then u got stuck rings, which keep running the bike and keep a eye on the oil, or you need the top end rebuilt.
Nov 21, 2008 | kawasaki Full Suspension Mountain Bike Men
Health & Beauty Logo
212 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
