Model WFW915WW01 WON'T PUMP OUT AFTER RINSE CYCLE
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: stops during rinse cycle and
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 11, 2011
Kenmore heavy duty 60 series model 110 91566210 won't drain- what now?
Not draining could be blocked or faulty pump, If you could hear the pump, probably blocked check filters, check pipe work, including the external drain hose. If you cannot hear a pump run, could be faulty pump, or could be totally blocked with something, jamming the impellar, would need the pump taken out or pipes disconnected from it to clear
Mar 05, 2013 | Washing Machines
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer will not rinse on any cycle
Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessingthemobilian_3073.jpg
Oct 26, 2011 | Kenmore 23822 Top Load Washer
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
