Question about Haier 8,000-BTU Commercial Cool Portable Air Conditioner CPB08XCL-LW
How too operate cooling modes
Need owners manual
The system is on in cooling mode and I have it set for 16 degrees celsius. It does not drop to below 24 degrees. I have it set up correctly but just doesn't seem to want to get cool. Any...
If you're running the dehumidifier at the same time as the cool mode. That's the problem. The dehumidifier mode generates heat and the cool mode operates at half capacity, when both are run at the same time.
To obtain a copy of the Owners Manual for your model contact the Danby Consumer help line: 800-263-2629, as your model has been retired. They can email you and copy as an attachment.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Danby DPAC10031 Air Conditioner
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
Control panel shows code 5A6 Replaced igniter and won't reset.
I'm afraid you may have wasted your money on a new igniter. The "error" your range is displaying is actually "SAB", which means it has inadvertently been set on "Sabbath Mode". This mode enables the feature for some religious faiths to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
NOTE: This generally does NOT indicate a component malfunction. This is an operator function that can often be set by accident (usually when attempting to adjust the clock for daylight savings time).
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off. If the model number is correct, according to page 12 of the Owner's Manual, to cancel the Sabbath Mode, you need to press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. Your manual can be downloaded, or printed for FREE.
If you have questions, please post back and let me know. I hope this helps you.
Apr 23, 2011 | Amana AGR5715QD Gas Kitchen Range
Code came up when trying to set tim code " 5A6 "
The error your range is displaying is actually "SAB", which means it has inadvertently been set on "Sabbath Mode". This mode enables certain religious faiths to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number is correct, somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off. According to page 17 of the Owner's Manual, to cancel the Sabbath Mode, you need to press and hold the CLOCK button for 5 seconds.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Sep 07, 2010 | Magic Chef CER1115AA Electric Kitchen...
Error 5sb on maytag gas oven. How do I reset it?
Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 5 seconds. The instructions are listed on Page 12 of the owner's manual.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please let me know. I hope this helps you.
Apr 02, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Have error code 5A6 on display
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 5 seconds. The instructions are listed on Page 13 of the owner's manual.
Mar 15, 2010 | Maytag MER5775Q Electric Kitchen Range
Apper 5 AB on disply
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 3 seconds, then use the arrow keys until 8:88 appears on the screen to clear Sabbath Mode. Release and the current time will reappear. The instructions are listed on Page 5 of the owner's manual.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. I hope this helps you.
Mar 09, 2010 | Maytag PGR5710 Performa Gas Kitchen Range
SA6 indicator is on...oven does not turn on...what does this mean
If you can't find this information, or no longer have an owner's manual, please post back and let me know. Please include your MODEL NUMBER when posting questions, so that we may be able to provide yo with better service. I hope this helps you.
Feb 12, 2010 | Kitchen Ranges
How long does self cleaning take?
Self clean mode can vary between makes and models of kitchen ranges, but it usually averages 2 to 4 hours. Once the self clean mode has been started it cannot be stopped until it completes the cycle and cools down. The oven door will lock and will not unlock until the internal oven temperature cools as the oven will super heat to about 700 or 800 degrees. Some manufacturers will enable the consumer to vary the self clean cycle time. Refer to your owner's manual under the Operating Instructions for specifics.
If you no longer have an owner's manual, you may be able to obtain one on line at managemylife.com. Just type in your model number under the "Manuals" link and see if it is listed. They have an extensive list of owner's and installation manuals available in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 04, 2010 | Frigidaire Gallery 30" Self-Cleaning...
5Ab bATH code.
Your display is actually reading "SABBATH". This is an indication of a mode of operation rather than an error code. The following link explains:
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differe in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
Dec 25, 2009 | Kitchen Ranges
Haier 8,000-BTU Commercial Cool Portable Air Conditioner CPB08XCL-LW Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
