Question about Hammering
Ridgid of45175a runs but has no pressure does not turn off
How do I fix an idle issue with my Ridgid 3000 psi pressure washer?
Run some carburetor cleaner through it first. Go to autozone, etc, and pick up some fuel system cleaner you can put directly in the tank and run it through.
Jun 21, 2014 | Ridgid Garden
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Need a repair breakdown on ridgid 3000 suburu engine
Go here and get the manual. Inside you'll find links for your engine and the numbers you'll need to get the literature.
https://www.ridgid.com/us/en/literature-search
Sep 11, 2013 | Ridgid Garden
Pressure lost
Pump issue. Go here and get the part number for your pump by model number. You can buy direct from Rigid.
Aug 31, 2013 | Ridgid Garden
Ridgid mobil airpressure switch trouble
This condition will occur when the in-tank check valve is stuck open. Pressure from the tank increases load on the motor by flooding the pump with tank pressure not allowing motor to start thus reset opens. Easy test. Run compressor for one minute then unplug cord from wall. Remove hose at the check valve and test for leak with soapy water. If leaking remove valve and attempt cleaning or replace with generic valve. Cost about $20. Good luck.
Sep 08, 2012 | Ridgid Compressor With Toolbox On Top
Gas is mixing with the oil on my ridgid pressure washer what is wrong?
the needle valve in the carb is not seating and gas over flows into the crank case
May 20, 2012 | Ridgid Garden
Hammering Logo
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
