Question about DeLonghi CF210 Portable Air Conditioner
Delonghi pac an140hpec trips the GCI on the plug when turned on.
When thee unit is turned on it beeps, the alert warning flashes and the GCI on the plug is tripped and shuts down the unit.
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
  • 9 Answers
SOURCE: Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Posted on Jun 08, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
SOURCE: Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
Unit beeps several times and gives warning symbol does not start
I have a Mitsubishi air con that has broken down like this twice because gecko's have gotten in and shorted it out. We had to have the circuits replaced at $1000 a pop. I think it can short out after a lightning storm too.
Nov 29, 2012 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
Compressor not turning on - but unit turns on and fan works - even when temp turned all the way down.
all the way down is as warm as the refrigrator can get. Sounds like start components are the problem.
Apr 17, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
We have a delonghi pinguino pac-t105 which just doesnt get very cold.
Instructions Things You'll Need:
  • Clean cloth(s)
  • Garden hose (if necessary)
  1. Verify that the air conditioner is connected to a power supply if the unit is not operating. Reset the circuit breaker or fuse if necessary and ensure that the electrical cord is plugged firmly into the unit.
  2. Clean the condenser coil with water from a garden hose and wipe down the fan motor blades with a clean cloth if the air conditioner is flashing a yellow alert light or is not operating or cooling as expected. Remember to turn off and unplug the air conditioner prior to maintenance.
  3. Adjust the thermostat to a warmer setting if the air conditioner is producing air that is too cold. Adjust the thermostat to a colder setting if the air conditioner is not producing enough cold air. Allow a few hours for the colder or warmer setting to take effect.
  4. Clean away leaves, dirt, branches or other debris away from the main unit if the air conditioner is not functioning well or the motor is running excessively. Clean the grilles and vents to allow for proper air flow.
  5. Contact an authorized service professional if the above steps do not resolve the issue
Jan 17, 2011 | DeLonghi Heating & Cooling
Selonghi pinguino super pac 26 works fine for about 20 min the turns off with the warning light that is the same as the power light flashing. How can this be fixed as apart from that it is fine. I did...
I had the same problem. Except it only lasted 10mins. It turned out that the water pump was not moving enough (any actually) water to cool down the heat exchange unit. The unit turns off if it overheats. I pulled the back off and realised that the water resevoir container was full of lime & calcium scale. Some of that had obviously got into the impeller blade in the water pump. I removed the water pump & hose and discovered a lot of hard crud in there. Cleaned it out, reassembled and hey presto the water was flowing agin and the heat exchanger was happy. Problem Soved. Anthony
Nov 21, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac 160 ( with air condition & dehumidifier modes) pINGU
i would like to know if the =unit turns off when it get to the tempature that you put it at
Mar 25, 2009 | DeLonghi DE500P Dehumidifier
Delonghi pac-02 a/c
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DELONGHI PENQUIN PORTABLE AIR CONDITIONER MODEL PAC T110P Recently started a Loud HUMM which would cut in every few minutes. Even if the unit was turned off but power still flowing to it. Now got F1...
Not sure why but un plugging and leaving of for a day seems to have reset the unit. now working fine ... for how long we will see thanks for the advice.
Aug 23, 2008 | DeLonghi Heating & Cooling
Delonghi PAc 60 it just stopped 12 months later with a warning light
Reset the GFIC if it has it.
Bypass it if you know how. they go bad often.
or open the unit and use an ac meter an make sure it is getting power at least , trace the ac cable to the board. and test.
Careful it may hurt bad.
Jan 25, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
75 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
