Problems with Audio system
I have a Audio system for my computer, but i plugged in the earphones, and once i removed the earphones i cant get any sound out of the system
  • Audio Player... Master
  • 5,391 Answers
If the audio is there when you fit the headphone jack back in, suspect a faulty headphone socket.
Posted on Jul 24, 2013
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 17, 2011 | Sony DAV-S400 System
How to connect my computer audio to pioneer vsx515 reciever..
here the steps:
1. locate the earphone jack on your pc.
2. after finding the earphone jack from your pc you need a connector (baby stereo plug to 2xrca plug).
3.connect the baby stereo plug to your earphone jack and then the rca plug to your Pioneer axuliary in.
Jan 02, 2011 | Pioneer VSX-515 Receiver
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
EARPHONES NOT ABLE TO PLUG INTO MONITOR.
Hi, I hope you've solved the problem.  But if the first solution does not work for you maybe this one will.
I looked at the specs for your monitor. LINE IN is for plugging in a device that makes sound, so this is not the right hole (called a jack) for the headphones plug.  Look on the back of your computer for a hole that is outlined with light green.  You wrote that you removed " the audio wire that connects the monitor to the CPU", this would be the place to plug in the headphones.
May 21, 2009 | Hannspree Hanns.G HW191D 19 inch...
Mp3 player
you'll need the reqired plug for this.like earphone plug or rca plug.depends on the socket.mp3's usually use the earphone plugs because it's small.after having all the necessary plugs, plug it where it says audio input or input or aux(auxilliary)
May 13, 2009 | RCA RS2047 Shelf System
I plug in the earphones and i cant get half of the music or sound
Your problem sounds like the male end of the earphones is not making a complete with the mp4 player. Make sure the connection is tight
Jan 10, 2009 | Audio Players & Recorders
Conection to my computer
I burn CD's on my laptop connected to a HM-33 through the earphone out plug. You have to change the computer's system input sound preference from "system" to "Audio in". Stereo sound quality is excellent.
Sep 04, 2008 | Kenwood HM-333-S Shelf System
 Grubhead
Grubhead
