Question about Annovi Reverberi Garden
Head torque specs. AR XMV 3000 psi pump - Annovi Reverberi Garden
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
  • 68 Answers
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
Posted on Apr 25, 2009
  • 462 Answers
SOURCE: what torque spec for chev aveo 2004 cylinder head
18 lb ft+60°+60°+60°+10°
NEW HEAD BOLTS ARE REQUIRED WHEN REPLACING THE HEAD OR HEAD GASKET.
Posted on Jul 04, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
What is the torque specs for a cylinder head for a craftsman air compressor 150 psi 7hp 60 gallon
The spec is 25-30 ft lbs.
Here are the specs.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D22629/d22629.pdf
Oct 10, 2010 | Craftsman Air Tools & Compressors
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Model #1578961A. The pump pressure cuts in and
usually caused by a supply problem, make sure you have enough water comming into the pump and that the screen in the connection is clean
Nov 15, 2009 | Northstar Pressure Washer 3000 PSI
What are the head and rod bolt torque specs on a honda gx390 engine
one hundred ten inch lbs on the rods and 45 ft on the head bolts
Nov 14, 2009 | Honda Pressure Washer PSI 3000
Pump cycles when trigger is not open
it is normal,It is the governor on the engine that does this.
May 07, 2009 | Briggs & Stratton Garden
Apr 25, 2009 | Craftsman Air Tools & Compressors
87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Jan 09, 2009 | 1988 Suzuki Samurai
Garden Logo
Top Annovi Reverberi Garden Experts
Bill Boyd
jeff chenault
jeff chenault
Tom Chichester
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
