Question about Plumbing
Eurostream faucet repair
How do I remove the cartridge from Model GE457617, Kitchen pull out spray model?
2 Suggested Answers
SOURCE: leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Posted on Aug 25, 2010
How do I replace the cartridge in my Moen 7065 Vestige Single Handled kitchen Faucet?
first the water needs to be shut off, then with an allan wrench if i remember it should be 1/8. the allan screw is located in the handle. remove the screw completely and under the handle should be a nut, with a crescent wrench remove the nut and the cartridge should be ready to be removed. it is going to be difficult to come out with out the proper moen tool but vise grips will help as you have to pull straight up. if you find a plumping wholesale and give them the model # they should be able to give you the right cartridge. or if you call moen the will ship you one either way it should be free as that is a warranty item.
Aug 26, 2012 | Moen 7065 Vestige Single-Handle Kitchen...
I do not have the side spray, but there is a dripping that is getting hard to stop. Can't stop the drip and would like to know what I need to do to fix. I have already tightened the screw on the top....
faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
Aug 30, 2011 | Kohler FortĀ© Single Lever Handle Kitchen...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Kohler - Coralais Pull-Out Spray Kitchen Faucet
te leak most likely is the cartridge you need to take the handle off and there will be a lock nut under where the handle was, turn the water supply off and remove the nut the cartridge will pull staight out, cartridges can't be repaired they need to be replaced. Watch out because some cartridges cost more than what the tap is worth
Jul 12, 2010 | Kohler K-15160-7 Coralais single-control...
Leaky eurostream kitchen faucet
Jun 19, 2010 | Plumbing
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Eurostream kitchen fuset 4513-15-bn
How can I replace the cartridge as the faucet leaks from the spout in closed position?
Sep 23, 2008 | Plumbing
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
