Question about Garden
The mower starts but will not go forward or reverse,(toro riding mower).
2 Suggested Answers
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
TORO 120 DIES IN FORWARD OR REVERSE WITH OUT PTO ENGAGED PROBLEM JUST STARTED
Initial thought is carb problem. I would look at the choke being stuck first. If not then possible debris in it. I would suggest a rebuild and cleaning of the carb then.
Jul 15, 2016 | Toro Garden
I have a craftsman 54 riding mower . It will start but won't go forward or reverse.
Check the lock out lever on the back of the mower. Has someone pulled it out? If so, push it back in and you'll have both forward and reverse then.
Aug 03, 2014 | Garden
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Toro wheelhorse riding mower 1638hxl very slow forward gear
if it works fine in reverse adjust the linkage rod on the pedal
Jun 08, 2012 | Toro Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
