Question about Electronics - Others
I have an npower 3000 watt inverter & when it comes on it powers up for about 30 seconds then alarm goes off & it displayed a ocp code. It will show 13.5 input but only 1.15 out put . What could be the problem?
brainyass
  • 242 Answers
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Posted on Oct 24, 2008
SOURCE: BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Posted on Oct 25, 2008
  • 3 Answers
SOURCE: aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
  • 1684 Answers
SOURCE: ACER Al1916W goes blank in 3 seconds. It shows
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
Nov 26, 2016 | Inverter Electronics - Others
Why does my 900w microwave trigger the LUP code & alarm?
you need at least a 1900 watt inverter with a fully charged battery to run a 900 watt microwave,it uses 900 watts to make microwaves and it uses 700 or so to run everything else.
Mar 11, 2015 | Inverter Electronics - Others
My 3000 watt aims inverter/30amp charger seems to work but the charger will not charge/transfer when I turn on the generator. Charging indicator will not come on. It does transfer the generator power
dear see that :
1- the range of voltage which inverter work between it for example 180-260 v
2- most small generator voltage reach more than 260V so the inveter not work
3-check the frequency of genaratoer if it not fix the inverter will mot work
Oct 12, 2014 | Aims Power AIMS PWRIC300012W 3000 Watt |...
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Cobra 1500w inverter runs for 4 min. and then shuts off with the code OPC.
Hi
Is the code OCP?
If it is not the code appearing in the display, then it is not a user code but O does refer to an over tollerance situation and L refers to an under tollerance situation can you clarify?
Oct 30, 2013 | Cobra Electronics 1500 Watt Triple-Outlet...
Grundfos cue inverter drive with a pump CR45-2 is showing an alarm code of 16/47 and 16/1 we cannot figure out what is tripping this alarm how can we trace this down and get corrected
this caused when you dont have rt guage cable to provide correct voltage,what wattage of inverter you have,if it is a 1000 or more you may have to have a 6 guage cable or 4 if more than 1000 watts
Jul 07, 2011 | Electronics - Others
I need to install my inverter 18 feet from my battery
a very thick one,,,like a baby battery lead on your car,,,its a very bad idear to have it so far away from the battery point, you would be far better off finding a closer place to put it as the volts drop off would have a big drop in out put on the inverter,,,also thats one big mother of a fridge to use 3000 watts????
you need a small power station to run it,,and if it do use 3000 watts your inverter is far to small to do the job, read the out put plate on the inverter,,it says 3000 watts max? not all the time,,,,thats about 2000 watts realy running contently and the whire to feed the inverter will need to carry about 30 amps so your car battery is say 90 amp hours plus the volts drop off, you would be lucky to have the inverter running for 3-4 hours before your battery go's is very flat on you!
Mar 28, 2010 | Inverter Aims Pure Sine Wave Power...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
