Question about Garden
Walker mower i have a walker mower with a 20 hp kohler command that runs rough somtimes when it does i advance the choke and it smoothed out somtimes it does it after it runs awhile
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
mickey813
  • 472 Answers
SOURCE: Kohler command 20 Hp. engine on walker mower
you can lub it up with some 3m oil if that dont fix it than it may need a new one
Posted on Oct 01, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
BAMOUT
  • 2478 Answers
SOURCE: my briggs and stratton mower runs rough but when I toggle choke on and off it runs better for awhile
have to use choke means fuel problem. Check your fuel cap vent, fuel filter. Fuel solenoid opening with key turn on. Remove hose from carb.and see fuel runs out.
Posted on Mar 10, 2012
  • 6468 Answers
SOURCE: My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Posted on Aug 12, 2012
Engine run around 5sec and dies
It sounds like you need to clean out your carb, if it runs for only 5 seconds it is using the gas in the bowl and the bowl cannot fill up fast enough to keep up with
Try leaving the choke on which causes more suction in the carb, but I would clean the carb using a torch tip cleaner to clean all the small holes, also remove the Welch plug and clean the hole under the plug the replace the plug with a new one
If you leave the choke on will it run longer, leaving the choke ok causes the more suction in the carb that is on way to test it, another way is to makr sure the the air filter and cover
Sep 22, 2017 | HP Garden
Engine dies when engaging blades
pull the carby and clean out the bowl and main jet
check for a blockage in the fuel lines to the carby, including the fine mesh filter in the tank at the tap
Jul 29, 2016 | Kohler Command OHV Horizontal Engine with...
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
Aug 11, 2012 | Garden
Small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Sep 25, 2009 | Garden
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
