How can i clear error code E000732-0001 on Canon iR 2570Ci?
  • 153 Answers
SOURCE: Canon IR 3200
ok you have a hard drive error problem that is what the code refers to need to replace the hard drive, try to scout around for one out of another machine somewhere and put it in otherwise if you get a new HDD you need to reload all the machine firmware and you will need special tools for that and only canon technicians have access to that stuff,
as i am a canon tech myself
Posted on Apr 01, 2009
redzventures
  • 149 Answers
SOURCE: IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
Posted on Aug 30, 2009
  • 74 Answers
SOURCE: cannon ir 2570ci
E007 means that the fixing unit has an error. This unit gets very hot and is shut down if an error is detected to stop it over heating. You will need a qualified engineer to look at it.
Posted on Mar 29, 2010
canontech
  • 1219 Answers
SOURCE: ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Posted on Apr 26, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Posted on Jun 16, 2010
Canon ir c3220 error code e000110 0110 how to clear this code
Here is a link to the error in the online service manual. This error may require replacement of parts prior to clearing
Canon iR C3200 Series Service Manual E110 0x10 Error Code
Aug 27, 2016 | Canon Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Cannon ir 2570ci
Mar 27, 2010 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
42 people viewed this question
k24674
jasbo
jasbo
