Question about American Standard Home
Tighten toilet seat for a cadet 3 skirted toilet seat
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
SOURCE: We have 3 soft closing Toilet seats.Newly
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Posted on Aug 01, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
olddewsons
  • 38 Answers
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Posted on Oct 11, 2009
tsolinac
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
How to tighten the seat on toilet
Put your hand around the back of the seat and you will feel the nuts. Tighten them by simply turning them.
Sep 02, 2014 | American Standard Cadet 3 Right Height...
Fix an american standard slow close toilet seat
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
Aug 02, 2014 | American Standard Cadet 3 Right Height...
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
Feb 26, 2011 | American Standard Cadet 3 Right Height...
The close coupled toilet seat keeps coming loose. The two phillips screws keep turning and won't tighten. There seems no way to get to the captive nuts...???
I too could not figure out how to get to the nuts since the skirt completely encloses the base. Nor could my plumber until he called his plumbing supply store. They told him they use a type of rubber piece that can be pushed through the hole from the top and acts as a nut. I didn't see it replaced so I don't know the details but I do recall that when I tried to turn those phillips screws that there was a squishy feeling. I don't know how to tighten under those conditions. I recommend you call a plumbing supply store.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
Installed cadet 3 and every twenty minutes it will run for about three seconds and i know it isn't supposed to do that
EITHER THE FLAPPER IS NOT PROPERLY ADJUSTED OR YOU WILL NEED A NEW FLAPPER. WATER IS SLOWLY LEAKING BETWEEN FLAPPER AND SEAT. AS WATER LEVEL DROPS ,TOILET WILL RUN TO BRING WATER LEVEL BACK TO PROPER HEIGHT.
Jan 06, 2010 | American Standard Cadet 3 Right Height...
I just installed two A/S Flowise Cadet 3 toilets..how tight should the tank be bolted down to keep it from rocking?
The tank should come down until it touches the bowl. You tighten one side a bit and then the other to bring it down evenly. You have to be looking in between the two as you tighten.
Sep 05, 2009 | American Standard Cadet 3 FloWise...
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Sep 04, 2009 | American Standard Cadet 3 Right Height...
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Aug 01, 2009 | Villeroy & Boch Home
Home Logo
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
