Question about Refrigerators
Samsung rf4289HARS LCD screen won't turn on. Everything else works, ice machine, refrigerator, etc. Screen just black. ??
SOURCE: Toshiba Qosmio E15-AV101 15' LCD screen went black
utube.png You-Tube video "
Posted on Mar 31, 2008
SOURCE: refrigerator ice machine
My understanding is Whirlpool has a one year warranty. Mine is not working but it is 3 years old. Maybe your warranty is still good.
Posted on Sep 01, 2008
Sea Breeze
  • 4655 Answers
SOURCE: ice maker makes ice,but won
Does your dispenser face look like this part number WR55X10415
If not then we need to look for the correct model number in the photo locations below. I think the control board is shorting out behind this panel.
You can visit my sites below and enter model or part numbers for your refrigerator. Also I will be here to help you get the problem fixed, Thanks Sea Breeze
SITE 2=> http://appliancepartseast.blogspot.com/
SITE 1=> http://servicepartstec.blogspot.com/
Posted on Jul 13, 2009
p4prince2par
  • 285 Answers
SOURCE: My Samsung gt-e2120 phone won't work. When you
are u tryin to say that it hangs
if yes then wash da circuit with lpacid
excluding da lcd
and dry unit with blower
and if there is any strip replace it
and before this try flashing the firmware
Posted on Jun 12, 2010
diodeic
  • 1622 Answers
SOURCE: everything in my refrigerator is
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
the cold control and the air deflector
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Posted on Aug 11, 2010
Error Codes on our Samsung RF4289HARS refrigerator: Error Code: 6E, 2E, 25E, 73, 40E
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
Oct 28, 2017 | Samsung Computers & Internet
My samsung model RF4289Hars refrig ice machine wil not make ice now i pushed on the button then it said to push reset button where is that Gary
The reset button should be on the icemaker, mine is a clear rubber button, I have my icemaker in the door so you fridge maybe different.
Jun 09, 2015 | Samsung Refrigerators
What is wrong with my ice despensor not turning to kick out the ice that is being made?
door latch switch , thinks door is open
or the motor is stuck /frozen
or the
front ice dispenser switch
does it switch to water an dispense
does the arm try to move /jitter,
being a geared down motor you can't /not turn it manually or can damage the teeth.
you might need help
Apr 18, 2015 | Samsung Stainless Steel French Door 28 Cu...
My Samsung RF4289HA refrigerator freezer section has been building up sheets of ice up to 1 inch thick every 30 days. What is causing this? Either an internal leak or a broken defrost cycle?
Per Samsung it may be that the vents in the back of the section are partially blocked.It could also be due to poor seals around the door. I have the same problem. Mine are definitely not blocked and my seals are almost new. The ice is due to poor circulation for defrosting. I learned to live with it. Every month, I pull the unit apart..remove the ice on the bottom. I got the procedure down to 7 minutes, Samsung was no Help. I think they do not want to admit a Design Flaw.
Sep 22, 2014 | Samsung RF4289HARS French Door...
How to reset calibration?
Just chat with the technician, press and hold the Epicurious icon for 5 seconds, the calibration screen will be shown for re-calibration.
Jul 12, 2014 | Samsung RF4289HARS 28.0 cu. ft. 4-Door...
Screen is going black
try to open your cellphone and reinstall the lcd,if same result then lcd is damage
May 25, 2017 | Samsung Comeback Cell Phone
I have a Samsung Rogue my screen won't turn On but
The connector for the screen is usually a very flimsy peace of material between the main board and the LCD. This comes loose a lot especially on sliders or phones that get dropped etc. The Rogue is probably out of warranty so you can attempt to fix it yourself by taking the phone apart and locating the connector and attempting to reset it.
Mar 28, 2012 | Samsung Cell Phones
Lcd screen flashing 88 8Y
I have a samsung french door that was also displaying 88 8Y and found out that it's an error code for the ice maker, I removed the wire cover, disconnected the ice dispencer connector, and then removed the ice dispencer, made sure nothing was stuck inside, plugged in the connector, pushed the reset button, and then put everything back. Unplugged the unit for about 20 min, and when I plugged it back in everything worked. I can't take the credit for this, a thread at applianceguru.com/forum1/8630.html helped me out on this one.
Apr 16, 2010 | Samsung RM255LASH Side by Side...
Ice machine not working
My ice maker tray is not filling with water everything else works, water in the door etc.
Jul 11, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
