Question about Garden
3.75 hp 94202
How to separate fuel tank form carberator
5 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Fuel not getting to carberator from gas tank.
YOU MAY NEED NEW FULE LINE
Posted on Sep 30, 2009
ftw1952
  • 10319 Answers
SOURCE: 1988 chevy celebrity No fuel to the carberator.
without starting the engine position the key to the on position.
you can hear the fuel pump operationing for 4 to 6 seconds upon having the key on.
if not heard running check the fuel pump fuse, the fuel pump relay, and the engines oil pressure switch.
they all work the pump you see
the engine oil pressure switch runs the pump untill the engine reaches normal pressure
once the pressure is reached to the normal range the computer shuts that circuit off and turns the fuel pump relay on
Posted on May 22, 2010
japkid
  • 107 Answers
SOURCE: 1995 g20 Chevy van....it has been sitting for a
is the fuel pump turning on? if not check the wiring harness for the fuel pump aswell as the ground. if its turning on an still no fuel, possibly could have put the fuel filter in backwards
Posted on Feb 08, 2011
Terry Corrow
  • 10875 Answers
SOURCE: How does carberator separate from tank on
on,,,,,what?????????????????????????????
Posted on Jun 29, 2015
Help my 1753 diesel MK4 Mondeo refuses to start have changed fuel filter still will not start
You just don't have fuel to the injectors yet. I use this to keep from running my battery's down and to quick start. Use a small air compressor to pressurize the fuel tank with any vent lines plugged. This will push fuel all the way thru and you can crank it up quick. Mine's and old '75 Chevy pickup with 6.2 diesel and I had a lot of tank changeover problems so I had to devise this to make it work right. I open the fuel water separator and let the pressure push the fuel finally into an empty bottle, shut the compressor off and close the water drain at the separator, crank it and it fires right up.
Jul 13, 2017 | Cars & Trucks
Is there any known problem/fault with the BT50 (2013) utility getting water in the fuel tank
check the seal at the sender /pipe pick up at the top of the tank
it is a small depression and any water sitting there will leak in
change where you are getting your fuel as water is used to clean out the tankers delivering the fuel and it is possible that contamination is being picked up from the under ground tanks
if it is a diesel, water forms from condensation when the hot diesel fuel is returned to a cold tank
if it is a diesel then to cut down on the moisture , keep the fuel tank as full as possible
use a water separator in the fuel line and use diesel conditioner additive in the tank to prevent a fungus that grows in that environment
for further information discuss the problem with an accredited diesel specialist shop --the best type of water separator and conditioner to use
Jul 11, 2016 | Cars & Trucks
John deer 175 riding mower won't pump gas to carberator. New fuel pump, can see gas in fuel filter7
could be a collapsed fuel fine from the tank. disconnect at filter and see if you can blow thru it to the tank .
Jul 10, 2016 | John Deere Garden
How can 10 HP briggs & stratton get fuel in the oil and what needs to be replaced?
The needle valve is not completely stopping fuel flow. The quick fix is to install a shutoff valve between tank and carbu
Aug 29, 2014 | Murray Garden
Will not start without priming the carburator, and then only run for a few seconds
It's not getting fuel thru the carberator another solution is the needle is stuck sometimes after it sets over the winter the needle ( which has a rubber end ) sticks closed
Apr 29, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1995 g20 Chevy van....it has been sitting for a year...ran before...changed the fuel filter and the fuel pump in tank is running but not getting any fuel to the carberator....blew out the line goin to the...
Feb 08, 2011 | 1995 Chevrolet G20
Hi there,i have a mcculloch tm210 petrol strimmer and the problem is that it will not start,i have noticed that the fuel primer bubble dose not come back out.please can you advise.
clogged fuel line or carberator. my weedeater did this at the first of the season. i took off both lines going to the gas tank and blew on each line separately while holding throttle open on carberator. i felt the clog go thru and put back together, poured a little gas in intake and it started right up and the primer worked right. good luck
Jul 03, 2010 | Garden
Not getting fuel to carb, mechanical fuel pump replaced.
SOUND LIKE STOP UP FUEL LINE.OR SOCK IN FUEL TANK STOPPED UP WITH RUST AND DEBRIS.YOU COULD HAVE A WORN FUEL PUMP PUSH ROD OR CAM SHAFT LOBE WORN WHICH DRIVES THE FUEL PUMP PUSH ROD.
Apr 28, 2010 | 1986 Chevrolet Chevy
Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
May 20, 2009 | Honda 8 HP Engine
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
