Samsung magic syncmaster CDP17s
My monitor screen is become small i want to be normal screen again, how i can do this?
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
viziks
  • 220 Answers
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Posted on Jun 16, 2008
Bat1956
  • 585 Answers
SOURCE: No 1440X900 Resolution Option in Display Settings
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Posted on Jan 24, 2009
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
Starworx
  • 4 Answers
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Posted on Dec 17, 2009
Samsung syncmaster magic cx 715B my samsung cx715B monitor, have a multiple horizontal line.what is the solution of this?
The multiple horizontal lines are indicative of screen failure. There really is no repair, except to replace the display.
May 05, 2015 | Samsung Computers & Internet
MONITOR DISPLAYING MANY VERTICAL LINES OF MANY COLORS
Hi Madan,
The screen of your monitor needs a replacement. Its faulty. Take your monitor to a qualified tech support in your area and have your screen replaced.
Nov 29, 2013 | Samsung SyncMaster 743N/743NX,SyncMaster...
My monitor menu on my samsung syncmaster 731n keeps popping up on the screen and I cant get it to stop
this is a normal condition for that kind of monitor, because it was design only with Samsung syncmaster 731n in which the old model. The reason why it always popping up is because it always adjust the setting of the images. The only way to solve this problem is if this menu appears again you only press the reset button there at the left side of the power button.
Aug 31, 2011 | Samsung SyncMaster 720N/731N
17'' samsung synchmaster 794MG model display but screen shrinks from all sides ,After few seconds display becomes very small just about in single inch size .
hit your MONITOR lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......monitor main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
Apr 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Black screen with power switch flashing blue.
I have been same problem but in other type syncMaster, the solution is open your LCD monitor look for power supply module (PCB which have connector to AC power), on that PCB look for capacitor , for normal condition its look like small tube. now look for broken one which upper part is bloated.
Nov 23, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung 753S focus problem
Focus controls are on the back of the flyback transformer. You may have bumped one while the back was off. Due to dangers working on live circuits I recommend you have a service professional adjust the focus.
Sep 04, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
