I am having ews70 washing machine electrolux brand. for this I required wiring diagrams. kindly help me.
IFIXALL
  • 868 Answers
SOURCE: Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Posted on Jun 03, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
  • 423 Answers
SOURCE: automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
Posted on May 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: hotpoint wm 53 first edition 1200 wiring diagram
Please reply with the model # if you still need the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Require a wiring diagram to connect contol panel
With no brand/model it's impossible to answer. Try Google search for (brand/model) wiring diagram.
Jul 10, 2016 | Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Washer wiring diagrams
Heating element, washing motor and bearing must be earthed.
Dado
Sep 02, 2014 | Electrolux EW1200i Front Load Washer /...
I am after a picture of the motor wiring on an ewf1282 front load Electrolux washing machine. There is a spare yellow wire which comes from the ECU, but the only place it looks like it will attach to
Good Morning Friend,
I understand that you are looking for a picture of the motor wiring for your Electrolux washer, model# EWF1282. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly. They might be able to get you a picture of the motor wiring. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Electrolux Washing Machines
Wiring diagram washing machine w3250n
Jul 29, 2013 | Electrolux Washing Machines
Manual for electrolux lt 959 washing machine
trying to find service manual for westinghouse (electrolux) top load washing machine LT959
Jul 22, 2012 | Washing Machines
Heater wiring diagram 7kg front loader electrolux
IN MY IFB WASHING MACHINE SENATOR TWO WHITE CABLES CAME OUT I DONT KNOW WHEATHER TO JOIN THEM AND FIX TO HEATER
WHAT IS THIS WHITE CABLE. AT CONNECTING POINT THEIR INSULATION ALSO GOT BURNED THAT IS WHY THEY CAME OUT
Jun 01, 2011 | Electrolux Washing Machines
How to replace door lock electrolux washing machine
Simple enough. Pull plug out and remove top cover of machine. There is a long way and short way so ill advise short way. The latter would require taking the boot off which needs expertise putting it back. Ok open front door and with screwdriver undo 2 screws holding the inner door latch. Place you one hand in the machine and then pull latch up high enough to allow you to pull wiring off. Note the position of those wires.(important). Once off, replace in reverse order, and test.
May 23, 2010 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
