Question about Ovens
HOW TO REPLACE CONTROL PANEL MAYTAG MEW5527DDB
Maytag wall oven mew5527ddb
I don't see a question but here is a link to see the manual. Maytag MEW5527DDB Oven Manual
Aug 13, 2014 | Ovens
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Fried a new oven
black is 110.v red is 110 v =220 volts white to center terminal . bare to frame of oven .. the damage could be to the pc board and the eoc ( clock) any fans ect . it may be more than you want to spend .. panel is 155.00 the clock is 155.00 fan 70.00 . you may not need all of this ., oven cost 764.00 / repair it .. mm /
Dec 03, 2009 | Maytag MEW5527D Electric Single Oven
I have a Maytag in wall oven (part# MEW653ODDS). Only three buttons on the control panel are functioning (cancel, convection bake, and favorites). The oven seems to work properly, but the number of...
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Nov 03, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Oven will not turn from top panel electric panel is stuck on 5a6
Unplug this unit for 3 minutes. if the control fault still exists after the 3 minute reset, replace the affected control board.
Jun 02, 2009 | Maytag MEW5527D Electric Single Oven
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Some numbers on panel does not work
I have the same problem. I can't see how maytag can say there are no quality issues since they don't track how many calls they get about the same problem.
Jun 17, 2008 | Maytag 30" Built-In Single Electric Wall...
Ovens Logo
70 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
