Favorite channel cox remote control model m7820
4 Suggested Answers
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: Cox DVR Universal M7820 GPX code not working
i have a message on my hd tuner and cannot turn off message
Posted on Apr 08, 2011
gopakumarg43
  • 75462 Answers
SOURCE: how do i tune my sylvania tv model srt2127s with remote control cox
Setup codes for Sylvania TV with Cox universal remote control are: 0054, 0030, 0381
[1] Turn on a device and, if applicable, insert video
media, (e.g., cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.
Highlight or write down the codes and device
you wish to program before moving on to step 2.
[2]. On the remote control, press a device key once
(e.g., AUX, VCR, TV, or CABLE). Press and hold
SETUP until the selected mode key blinks
twice, then release SETUP.
[3]. Use the Manufacturer's Codes.
Enter the first four-digit
code for your device. If performed correctly, the
selected mode key will blink twice.
NOTE: If the selected mode key emits a long blink, the
code is invalid. Repeat steps 2 through 3 and try
entering the same code again.
[5]. Aim the remote control at the device and press
POWER once. The device should turn off. If it
does not, repeat steps 2-3, trying each code for
your brand until you find one that works. If it
still does not work, try searching for the code
NOTE: If the device does not have a POWER key, press
the "Play" key.
Posted on Oct 20, 2012
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
WE love our MX3000 and it was installed about 9 months ago. However, now Cox has changed all the channel numbers from the 700's to the 1,000's. I cannot reach the guy from Eagle Sentry, here in Las...
Ask Cox cable to send u a new listing of the numbers of channels has been changes or u have it already?Sorry no,not really.Read ur universal remote manual,just reprogram the channels numbers that all.
Aug 10, 2011 | Universal Remote Control MX-3000 LCD...
Channel lock is stuck on
May 28, 2011 | Televison & Video
I want to program the digital channels onto numbers on the remote.
The remote will have a DASH or DOT key to let you enter the digital channel numbers directly,
as in: for digital channel 53.2, you'd enter "5" "3" DASH "2"
To program digital channels into a FAVORITEs list, you'd have to provide the Mfr/model
of the remote control itself...
Mar 28, 2011 | Samsung PS42P2S 42 in. Plasma Television
002,
008,
155,
198,
227,
231
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
LC321SS9 remote code and cox remote can not find universal code
I have the same TV and the same problem. I exchanged the Cable remote for a new one and did the auto search. (hold the tv button/Sel key then channel up key) It worked with the new remote. I believe the code is 121
Jan 14, 2009 | Zenith ZEN450 Remote Control
Favorites
For a DirecTV reciever it's better to program your favorites using the function built directly in the receiver. For most models you'll just go to the set-up menu and find the favorites menu item. It will allow you to create a subset of channels. Hope this helps.
Mar 11, 2008 | Universal Remote Control DIRECTV Universal...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
