Question about Garden
158cc MTD PRO 500 Series
I change the blade,flter, spark plug and the oil because it was running poorly. Now its running great but its turnnig way too fast. Feels like its gonna tear itself apart. How do I adjust the the speed. Thetrottle is one bar on the handle. Its got to be held down or mower wont start or run No speed adjust . Need to slow it down a bit?
4 Suggested Answers
  • 885 Answers
SOURCE: My 22" MTD Yardman push
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Posted on Aug 31, 2010
  • 2239 Answers
SOURCE: 07 mtd yardsman mower with 13.5 tecumseh runs great untill engage mower , then dies down and blows black smoke
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
Posted on Jul 08, 2012
  • 6468 Answers
SOURCE: how do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Posted on Jul 19, 2012
Lawn mower ran out of oil and stopped running put new oil in and still not running is there something to do after putting oil in to make it run
If you can turn blade by hand first removing spark plug you then can try squirting 30w oil into plug hole and turn blade by hand. replace plug and try to start. Depending on whether you gouged the cylinder it may start.
Jul 06, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Briggs & stratton engine 500 series 158cc + spark plug gap
Look up your engine on the Briggs&Stratton website.They have all the specs. Or call MTD.
May 18, 2014 | Mtd 22" Yard Machine Push Mower
How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Briggs & Stratton Garden
Where is the oil plug for my 2004 MTD mower. Model no. 12A-998Q795
Hello, The 2004 MTD Pro walkbehind doesn't have an oil plug per say. I am guessing you wish to perform an oil change. The oil filler cap/tube assembly is also the drain, as is with many walk-behind mowers. ( Here's a link of the engine breakdown showing the parts: http://www.mowerpartsweb.com/MANUALS/HONDA/GCV160A.PDF )
Make sure the gas has been drained/run dry - this will prevent accidental spills during this proceedure. Next, for safety, disconnect the spark plug wire. At this point, I usually have a couple of blocks handy to place the side wheels ( the ones on the side with the oil dipstick ) On your model it should be the right hand side. just at the edge of the fan cover cowling. between the blocks, have a container ready to catch the oil, I use one of those square margarine tubs as the sides are low - but any suitable container will do. Bear in mind, it should hold about 1/2 to one litre of oil. Be carefull not to tip the machine with the spark plug down - this will cause the air filter to become contaminated and lead to poor starts or not at all. ( If this happens, replace the air filter.) Now jus tip so the spiggot is over the container and allow to drain. Tip back into normal upright position and fill to propper mark. Simple Tip: save any oil containers - they come in handy for the used oil and are easy to take to the hazardous waste disposal.
Hope it goes smoothly!
May 11, 2011 | Mtd Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd yard machine snowthrower not starting, doesn't sound even like it is firing, new gas, new plug, oil is full, emptied gas tank and ran dry before storing last year, blizzard tonight, help!
First spray a prime down the throat of the carb with the choke in the run position and attempt to start. If the motor hits and runs for a second then its a fuel related issue and you will need to remove and clean the carb. If it wont run or try to run on a prime then it may be an ignition issue. check for spark. If no spark then remove the ground wire from the module and check for spark again. If still no spark suspect the module, if spark with ground wire removed then wiring or switch is the culprit.
And make sure you dont over look little things like... does it have a fuel shut off valve and is it open? Is there a safety key and is it in -place? etc.
Dec 09, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Dec 08, 2009 | Garden
Cant get blades off
Clockwise, but you need a good impact, or you'll have to give the wrench a good whack (which isn't a good idea). It's best to lock the blade down so it can't come around and cut you. Also, it's a very good idea to remove the spark plug wire.
Best regards, --W/D--
Aug 12, 2009 | Mtd Products Yard Machines 158CC Tiller
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
