Question about Whirlpool Heating & Cooling
Any recall model acp122gpw1
Fan broke
Heater won't stay on, I heard there was a recall on this item.
Hi and welcome to FixYa, I am Kelly.
I am only answering part of your question (Recall) so do not rate the post so other experts can help you with your heater won't stay on problem.
Your heater model is not one of the 4 models that were recalled.
The recall involves Holmes® models HFH6498-U, HFH6500-U and HFH6500TG-U and Bionaire® model BFH3530-U. The recalled heaters also have date codes beginning with 2604 through 3804 for all units, except for Holmes® model 6500TG-U, which has date codes ranging from 2604 through 4704. The model and date code can be found on the silver label on the back of the unit. The heater fans are 26 inches tall; come in all gray, two-tone gray, or black and gray; and have either the word Holmes® or Bionaire® printed on the front of the base.
See this link for more details:
http://www.holmesheaterrecall.com/
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
When on dishwasher made a funny noise and smoke was coming from it. now dishwasher is dead
Secure power to dishwasher at the breaker box by shutting off breaker. Some models
of Hotpoint dishwashers were recalled for electrical problems. The number for the model
and serial are inside the door on the left. You can Google for recall information.
I have run across 2 of the new dishwashers with the "square" motor pumps with bad
castings in the fan section which broke off and lodged in the motor itself.
On some models the drain solenoid will burn out and produce a nasty smell.
You can check underneath with the power off to see if the triangle shaped control
arm moves freely. You can also inspect the motor to see if it has a broken vane.
If you have aluminum wiring and the dishwasher was connected to it, often the wires
will work loose from vibration and literally burn a hole through the wire nuts themselves.
It would be located inside the connection box (Power off first before checking).
I do not recommend attaching aluminum wiring to a dishwasher for this reason.
Hope this helps locating the problem.
Mar 12, 2011 | Dishwashers
Is the crib with the model WM 1633-0 been recalled
Yes.. It has been recalled you need to call 1-800-295-1980 the recall dept # is 1-866-762-2304. I have the same crib and just found out because the drop rail broke!
Sep 10, 2010 | Dorel Alexander
Drivers side mirror "just the glass" fell out. Is that a recall problem?? Saab 9-3 2004
I am not sure if it's a recall on your model but they tend to fall out out a lot of different models you can use super glue them back in or you can by a new glass if it fell out and broke they'er $5.00 for the mirror and a buck for the super glue.
Apr 16, 2010 | 2004 Saab 9-3
Our GE Arctica PSS27NHN has gone out. We took a look inside and found the motherboard has a burnt spot, so that is most likely our problem. Can anyone tell me if this model is on the recall list. I have...
No recall list that I know of .G E now has 2 boards available . The pt# you need is WR55X10656 . Less problems than a board for each model .
Jul 19, 2009 | Refrigerators
Mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
May 16, 2009 | 2004 Mitsubishi Outlander
Blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
May 10, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
Overheating
First of all make sure there are no air pockets in motor.
Run vehicle with radiator funnel or if don't have one run with cap off until top hose is hot.
If top hose isn't hot then the thermostat is not opening, need to replace. and repeat bleeding procedure.
If it overheats it builds up pressure and causes overflow cap to relieve pressure.
WORST CASE SCENERIO:
water pump is bad not allowing enough flow through out the vehicle.
Feb 17, 2009 | 2000 Jeep Grand Cherokee
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Heating & Cooling Logo
47 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
