Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1185 hi i have a problem with scanning thingsit always prints well but only if you put 1peice of paper in a at time otherwise lots of paper goes through at once and it jamz,and with the scanner some times it works but not verey offten and i dont no why?
    Sergeant:
  • 390 Answers
You have two issues at same time. 1: your printer may have a jam somewhwere. remove all paper, and open unit cover, and see if you can find any bits of paper jammed, remember they can be minute and will still cause big problems. check thoroughly behind unit too, sometimes it helps to use a torch. When you put paper back in, only place a very thin stack, too much will cause feed problems and jams. Make sure paper rest is correctly installed too, and the paper guides either side are not pressing too tight on paper stack sides, they should sit gently beside in line with it not pressuring it. Also check if roller is even, inside and down back. Flick paper stack in fingers to separate pages and never feed bent dogeared or marked paper into unit, even a tiny little notch in it will catch. Try printing now. The scanner issue can usually be resoved by uninstalling the whole printer and reinstalling it, ensuring a thorough reset. Good luck and post back if no help.
Posted on Sep 01, 2007
SOURCE:
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do this.you can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Connecting to a mac
Despite Apple advertising,
Macs dont plug n play with very much
they need drivers,
Lexmark are pretty good with support software
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:435:0:0
Oct 20, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185
it does not take much to dirty up a printer even a little dust, try blowing a can of air, if that doesnt work the printer perferences might have changed either you have to thick of paper or not thick enoughtacording to your printing preferences or the page set up next time you go to print check the page setup
Jun 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185
hi I have lexmarkx1185 and it was working but i changed my software now it doesn,t work and i don,t have the software cd for my printer could you help me please
Nov 29, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 1200 All in One
I've never heard of that size paper the printer don't have that option the only possible sol. is to go to an A4 size ( European size) other than that try printing from Word and change the size of the Fonts.
Sep 17, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1185
It sounds like there is still paper inside. Remove all paper in the tray and if all is clear. Reload the paper and push the paper feed button. If this doesn't work unplug the printer on let it reboot.
Jul 31, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
