Question about Refrigerators
Why my GE Fridge stopped working after power surge
Need wiring schematic for GE Fridge Model GSS23WGTAWWW to troubleshoot why it no longer works after major power surge
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 291 Answers
SOURCE: refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
  • 193 Answers
SOURCE: Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Posted on Aug 14, 2009
  • 28 Answers
SOURCE: fridge stopped working after a power outage. When
You may be correct. Remove the back cover by taking out the screws (cover will have to go back on) and see if the complressor is really hot. Allow the compressor to cool down and then plug the unit in. If you hear a click after about 30 seconds; you may have damaged the compressor relay and it will have to be replaced with the overload located on the side of the compressor.
Posted on Aug 29, 2010
My fridge and freezer stopped working. Nothing's running. It doesn't cool or freeze. None of the mechanical parts are working. Only the lightbulb turns on. What can be wrong?
if removing the mother board made no difference to the fridge operation then it would be logical that the mother board is faulty
These machines do not like power surges( can originate many miles away)
have a technician check it out
May 06, 2015 | GE Refrigerators
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
After power outage, fridge does not work but freezer does
Sounds like a thermostat got damaged when the power surged when utilities were restored. Thermostats are usually behind the temperature controller. Hope I've helped. BB
Jan 20, 2010 | GE Refrigerators
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
Frigidaire gallery fridge model glhs269zdw1 not working after power surge..fridge lights are on and I can hear fan running..the water dispenser also stopped working.
You are hearing the evaporator fan in the freezer but not the compressor motor, therefore no cooling. This is a classic symptom of a bad control board - you will need to check and replace the circuit board ! best of luck
Sep 27, 2009 | Electrolux Refrigerators
Refridge stopped working after a power surge
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
Apr 03, 2009 | Refrigerators
The fridge is making a constant clicking noice
Had the same problem on my GE bottom freezer fridge. It finnaly died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Nov 28, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
THE TEMPERATURE READOUT FOR THE FRIDGE AND FREEZER IS BLANK AFTER AN ELECTRICAL STORM. THE REST OF THE APPLIANCE SEEMS TO BE WORKING OK. GE PROFILE MODEL#PDS22SFSALSS
A power surge? Possibly main control board, guess it's on the back of the fridge /covered flat metal plate/.
http://www.subzerolosangeles.com
__________________________________
Sub-Zero refrigeration Service experts
Aug 15, 2008 | Refrigerators
Fridge not working on 12V or 220V
hi simon, i would say your ac heater is gone bad. it could have open up and no longer heating when you have a power surge . these heating elemenent are also located in the gas generator. you have to replace this heating element.
Feb 22, 2008 | Refrigerators
Light is on but not cold.
My Freezer is working But my Refrigerator side is not getting cold like it should it is a GE modle
Jan 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
