Question about Frigidaire FAC126P1 wall/window Air Conditioner
Lra157mt1 water not draining
Frigidaire window air conditioner LRA157MT1 worked yesterday. Today fan works but it doesn't cool?
unplug it if you can and let it set for 20 minutes, set the temp control where you want it and plug it in, wait a bit and see if it starts cooling. you can confuse these things if you turn it off and on rapidly or change the temp control up and down sporadically. The compressor has to take it's time to kick on after it has been shut off and then on again.
Jun 11, 2017 | Frigidaire Heating & Cooling
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
Unit will not turn on, what do I do now?
there is a reset on the plug sometimes if there is press it
May 19, 2013 | Frigidaire New Original LRA157MT1 Remote...
Fridgadare lra157mt1 reset button keeps poping out
It is tripping the outlet breaker. Change outlets or you will have to back down on the power with a different unit.
Sep 03, 2012 | Frigidaire FAC126P1 wall/window Air...
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
Frigidaire lra157mt1
Some of the new style Air conditioners have a auto time delay built into them for power failures. If power fails or you unplug the unit, they will not come back on for about 3 to 5 minutes. This is a safety feature to keep power failures from damaging the compressor. Keep it plugged in for 5 minutes and try again. If still no go then call for service. You should have a 1 year warranty on it.
May 27, 2012 | Frigidaire Heating & Cooling
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Frigidaire FAC126P1 wall/window Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
