Question about Vacuums
Kenmore vacuum model 11629201900C
KC92PDJXZV06 NEEDS TO BE REPLACED
The motor is making a deep growling sound and has a burning smell
The motor is bad. It or the vacuum needs to be replaced. It would probably be cheaper in the long run to replace the vacuum.
Dec 11, 2010 | Kenmore 23313 Whispertone Bagged Canister...
We have a kenmore canister vacuum, the part that is attached to the wand that picks up the dirt doesn't work, when it's on the carpet the light does not go on. Do we need to buy a new vacuum or is there a...
Hard to say without the correct model number.
However, you could check these things first:
1- Is the belt that runs the brushes on the end pieces broken? If it is, is needs to be replaced. 2- Is there power to the control head that is not operating? This is a guess on my part since it is not possible to know the makeup of your unit without the model number.
Check these things and let me know how you make out and we can go from there, as long as I can get the model number.
Paul
Oct 05, 2010 | Kenmore Vacuums
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Wheels
The axle for the rear wheels have worn into the cut outs in the body that it goes through and they are rubbing on the wheel wells. This common for this vacuum model , the only real fix is to replace the body assembly. Sears will have to do this, this is NOT somthing you want to tackle by your self.
As for the machine locking upright that is the release lever and it just needs to be replaced.
Jul 16, 2008 | Kenmore 31913 Progressive Direct Drive...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Vacuum is making a loud noise
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Dec 03, 2007 | Kenmore 35622 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
