Question about AOC Computers & Internet
AOC 2367PH hotkeys problems
I bought a AOC 2367PH and it worked pretty well until yesterday. The hotkey for "menu" and "2D/3D" does not response at all...please help.. I have read some other question and tried to press the menu and power key together, they can lock or unlock OSD, but I can not call out the OSD with the menu key...please help, thanks!!
  • 30 Answers
SOURCE: OSD Locked
You can try this lcd monitor factory service mode login method here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/login-factory-service-mode-lg-lcd-mo.html http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/how-to-login-to-lcd-monitor-factory-service.html Try and see!
Posted on Sep 18, 2007
SOURCE: OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Posted on Feb 05, 2009
SOURCE: Unlocking of OSD in AOC LM725 Monitor
Solution #1 above fixed my problem. Turn the monitor off, then hold the left button down while turning it on again. Works like a charm!
Posted on May 04, 2009
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
SOURCE: OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Posted on Feb 06, 2010
Asus keyboard instructions
try reinstalling the atk hotkey drivers.
http://support.asus.com/Download.aspx?SLanguage=en&m=Q301LA&p=3&s=583
chose the operating system. under utilities you will find atk hotkey drivers. download and install them.
Jul 13, 2014 | Computers & Internet
Ive lost my hotkeys on my keyboard
Sounds like your keyboard driver has either stopped working or has been removed. Keyboards will function as normal without specific drivers but hotkeys etc. wont work. Look at the manufactures web site for keyboard drivers, usually they are pretty good at providing the downloads. without them installed correctly hotkeys will not work. Once installed run the software and check the keys assignments.
Nov 24, 2013 | Computers & Internet
Backlight & volume fn hotkeys g73jh not working
restart and HOLD the key f2 or esc for enter the BIOS setup, and adjust the hotkey, Enable.
God bless you
Jul 24, 2013 | ASUS G73JHA1 Notebook
Packard bell easynote hotkeys don't work after reinstall windows 7
Well it seams you did not download the software for the hot keys.
Oct 03, 2012 | Packard Bell Computers & Internet
I have a ASUS K40AF VX019R NOTEBOOK. It was infected with disabling virus that I have to have it reformatted. My problem is that I can no longer use the hotkeys of the keyboard. How will I reactivate...
I cant post the link here because its javascript.
Goto support.asus.com and in the search bar to your left, type K40AF and select All from the Category menu. Click search and select the product from the search result. Choose your OS, and install the drivers for your hotkeys. One of them will enable them.
Cheers.
Mar 16, 2011 | ASUS m6n Notebook
Hp notebook volume control is fluctuating randomly
Had / have the same problem in my dv5t - the culprit was the volume hotkeys on the case (right below the screen). As it turns out it's very prone to static electricity and tends to change the volume level up and down randomly.
In my case - simply swiping the whole hotkey area with a finger helped.
This is only a temporary fix and will pop up every once in a while.
There is no permanent way to resolve this (apart from uninstalling the hotkeys)
Oct 31, 2009 | HP Computers & Internet
Battery problem, hotkey problem
remove the battery then insert again,..
Jun 06, 2009 | Sony VAIO VGN-SZ460N/C Notebook
My games keep telling me {unable to create 3d device} when ever i try to acess my games e.g jamesbond nightfire
I CAN HELP YOU WITH THIS PROBLEM IT IS IN THE ADVANCE SETTINGS OF THE VIDEO CARD SYSTEM DRIVERS
GOTO CONTROL PANEL AND OPEN UP FOLDER CALLED DISPLAY SETTINGS
FIND BOX SAYS ADVANCE SETTINGS
OPEN THIS FOLDER INSIDE THE FOLDER YOU ARE GOING TO SEE ALOT OF OTHER FOLDER AND THEY MAY ALL HAVE THE SAME INFORMATION MINE SAYS:
ADAPTER,
COLOR MANAGEMENT,
MONITOR,
TROUBLESHOOTING,
GAMING,
ATI CATALSTIC [TM] CONTROL CENTER ( OPEN THIS FOLDER)
INSIDE THE FOLDER IT ASK YOU AGAIN IF YOU WANT TO OPEN IT AGAIN AND YOU WANT TOO CLICK ON IT
INSIDE THIS BOX YOU ARE GOING TO HAVE THE FOLLOWING INFORMATIONS:
GRAPHICS SOFTWARE & HARDWARE
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES 0 OR 1
3D SETTINGS
COLOR SETTINGS
AVIVO TM VIDEO
POWER PLAY
SOME OF THESE HAVE WHERE THE COMPUTER WILL SETUP CURTAIN DRIVER FOR THE GAMES YOU WANT TO PLAY, HELP FPS, GRAPHIC INTENSE, FAST SPEED, CONTROL SPEED OF FANS, CPU, COOLER DEVICES AND SO ON.
YOU WILL HAVE OPTION TO PUT THE ICON ON THE START UP MENU EVERYTIME THE SYSTEM STARTS UP SO YOU CAN MAKE CHANGES ON THE FLY.
OTHER OPTIONS: VIEW,HOTKEYS,PROFILES,PERFERANCES,AND HELP, AND SYSTEM INFORMATION
2D OPTIONS
2D DRIVERS FILE PATH & DRIVER VERSION
DIRECT3D
OPENGL VERSIONS
PROVIDERS
DRIVERS PACKAGING DRIVERS
GAMING OPTIONS
EVERRY GAME BOX YOU PUT A CHECK MARK IN WHEN YOU ACTIVATE THAT PROGRAM IT WILL LOAD YOUR DRIVERS FOR THAT GAME AND WHEN YOU SIGN OUT THAN THE COMPUTER WILL WANT TO RESET TO ORGINAL WINDOWS SETTINGS
REBOOT
ROD
Feb 21, 2009 | Dell GeForce2 MX, (32 MB) Graphic Card
Hotkeys doesnt work
just install the hotkeys driver from the acer website and they should work again! ^.^
Jul 12, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
255 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
