Question about Car Audio & Video
Jensen awm 965 dvd/cd will not load, keeps ejecting the disc
SOURCE: jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Posted on Apr 03, 2008
AlmostBob
  • 550 Answers
SOURCE: Disc does not load keeps ejecting disc
clean the player
the track that the loader runs on is dirty, hists the dirt and reverses to prevent damage
Posted on Sep 20, 2008
SOURCE: Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Posted on Oct 13, 2008
zappanut
  • 959 Answers
SOURCE: Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Posted on Dec 12, 2008
rulds2008
  • 3866 Answers
SOURCE: CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Posted on Aug 18, 2009
I have a Jensen DV2007 CD/MP3/WMA/DVD Player/Receiver and was wondering if it will play my Sony DVD-RW 3"mini disks
No they will not work as the loading mechinism would not be able to grab ahold of the discs. Normal cd/dvd's load because the mechanism grabs by the sides of the disc and the 3'" disc would be to small.
Sep 21, 2010 | Jensen AM/FM/CD/MP3 PLAYER WITH DETACHABLE...
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
Jensen's VM9312HD when i put the disc say's bad disc
it might need a lens cleaner disc...this is a common problem of using discs
Aug 10, 2009 | Jensen's VM9312 Car DVD Player
Magazine won't eject
HI, the load motor has failed in your changer and , you will have to replace this. its part of the loading dock assembly and it turns all the gears associated with the loading and playing procedures.
If you are hearing continuous clicks, this will be the reason for the failed motor.
May 21, 2009 | Jensen XCH6RF 6-Disc CD Changer
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen 9410 will not load or eject
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
