Question about Garden
Manual for TEC transaxle kit #799031... what parts from the kit are actually necessary to install new hydrostatic trans in a 1999 46" cut Murray?
SOURCE: I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Posted on Apr 20, 2009
SOURCE: I just got a used murray riding mower model #30544X92A
Go to Murray.com and they have their manuals and parts list. If you don't see your model E-Mail them your model and ask for the info. I did this with my older model Murray and the next day they E-mailed me back with the manual and parts list..
Posted on Apr 27, 2009
  • 130 Answers
SOURCE: need to find parts for riding mower hydrostatic transmission
yes it can be fix.but it might cost you alot of money.i will try to help you.let me know. want parts you need.i need a pic.i have lots parts.let me know.ok
Posted on Jul 22, 2009
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
I have a 1996 Murray tractor and the speed of the tractor gets slower the more it is run. Where should I start?
check belt that goes from motor to trans. check pulleys and the bearings in the pulleys for same belt.
Aug 24, 2014 | Murray Garden
I have a Murray 17.5 HP Twin 46" automatic drive riding mower that only moves very slowly. What are possible causes?
If the transmission is hydrostatic and has some hours on it, the transaxle may be going bad. If this has been getting worse as you use it. If the problem happened suddenly, could be a belt loose or stretched.
Jun 26, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Where is the hydrostat transaxle and filter located on my murray 17.5 ohv riding mower
the filter is internal on riding lawn mower garden tractors have external filters
Jul 14, 2012 | Briggs & Stratton Garden
I have a murray model F4316070 hydrostatic trans whines and vibrates when put in gear
not familiar with this model but sounds like it is going bad just keep driving it if it is like mine it is sealed and no way to put fluid in it
Mar 28, 2012 | Murray Garden
Lawn tractor with a K57 Tuff Torq transaxle. Runs well at first but then slows down after about 10 minutes of use and then will have no power at all.
It sounds like the hyrostatic parts in the transaxle have worn to the point of failing. The alternative solutions: replace the tranaxle w/ a new one ($700-$1100 plus labor depending on exact K57 model as there are 6 sub models like K57A, K57R, K57V...etc); find and install a used compatible K57 known to work well probably run $400-600 or more; find someone that can open up your failed transaxle, diagnose which parts are worn, & replace/repair them. I've repaired the worn hydrostatic parts on my transaxle myself and it runs as good as new. It can be done. If you want to discuss having this done, email me at idakiteman at gmail dot com
Aug 22, 2011 | Garden
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My murray 17 hp 42 inch cut hydrostat mower will barely go uphill
Aug 31, 2009 | Garden
Hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
May 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mar 22, 2009 | Garden
Garden Logo
148 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
