Question about Denon AVR-2307Ci Receiver
Receiver blinks green for a few seconds then blinks red and doesn't turn on
5 Suggested Answers
Foxyjay
  • 13 Answers
SOURCE: blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
Posted on Jul 22, 2008
  • 99 Answers
SOURCE: Denon receiver won't power on- blinks green then
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Posted on Jul 27, 2010
  • 186 Answers
SOURCE: the receiver turns off 2
have you got all the wires wired in correctly.have you extended your speaker cables and not insulated them(wires could be touching each other).maybe a blown fuse inside.although i think if it were a fuse,it probably wouldnt light up at all.my experience with my system is that if i wire up something wrong,the power button light which is a green light,will change to red to let me know something is not right.(its warning me before i blow something up)!!yours might be doing the same thing only flickering to let you know somethings wrong.If none of this helps then you should send it in for repair.Dont be afraid to open your system and look for a glass fuse(s) about 20mm long.if you find one and its blown,then you are lucky.a blown fuse is better than a blown system
Posted on Oct 17, 2010
  • 608 Answers
SOURCE: The receiver was on....working properly...and then
There is a good chance you have a faulty capacitor. There are lots electronic devices out there right now that are failing to power up or just shutting down on there own these days. Turns out many manufacturers of electronic boards installed faulty caps in their products.
I hate to say it but that sounds like the problem to me.
Solutions
1. Have it fixed by a professional
2. Open it up, Inspect the power board for bulged/leaking caps. If you find some you know you have found a problem. Replace the board.
3. Replace individual caps that are faulty. This takes a few soldering skills but can save you $$$$$$
Caps are very inexpensive and can be found at your local electronics store or online.
Hope this helps and thanks for using fixya
Kaufman605
Posted on Dec 11, 2010
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
After turning on the tv the green light comes on then it clicks back to blinking red after a few seconds
Issue with Logic Board Fail to innitial Voltage Safety Control Swich due to fails component inside TV Set... Please Refer To Certified TV Shop Repair ...
Oct 09, 2010 | Philips E-Box FTR9965 DTV Receiver
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Blinking red power light
May 25, 2008 | Denon AVR-1906 Receiver
Open Questions:
Denon AVR-2307Ci Receiver Logo
24 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
