Question about Mitsubishi VS-50707 50" Rear Projection Television
No signal through Ant-A and/or AntB
I can not get a signal when the coax is plugged into Ant-A and/or Ant-B, its just static. I can veiw cable when I run it through the vcr and change the input to input-1. The same time the Antennas quick working, the remote to the tv did as well. The remote still works on all other components.
  • BigDawg2 Dec 13, 2007
    I have the same problem
    I can not get a signal when the coax is plugged into Ant-A and/or Ant-B, its just static. I can view
    cable when I run it through Ant-A through cable loop-out to the vcr
    and change the input to input-1and change channels with vcr.
    President:
  • 4,402 Answers
Sounds like bad tuner
Posted on Dec 15, 2007
SOURCE:
Home stereo with outside antenna, when I insert the coax cable into the stereo the radio plays fine until the type f connector touches the radio and that is when the static starts, please help
Hello, Try terminating the other end of the coax cable with a 50 ohm resister. Also .this could happen due to overloading the input with strong signals. If you know some electronics, you could connect two back to back connected diodes(in 4148) at the radio input end to limit the signal level.
Feb 28, 2018 | Radio Communications
I set my box up and got a lnb error so I changed the coax 2 times and tried 2 diffrent audio video cables but nothing seems to fix the problem I'm using an old ant the plugs in the wall is that why
I suggest you invest a small amount of money in a signal strength meter, usually used for aligning antennas and dishes but can be used for diagnosing faults. If nothing is coming out of the lnb or not managing to find it's way down the coax the box will have nothing to work with.
If there is adequate signal arriving at the box it would indicate a faulty box or bad software.
Sep 05, 2016 | Televison & Video
Can't pick up ant ditgital signals,why not
First what make/model of TV do you have? Does it have a digital tuner? (Manufactures had to add digital tuners at various times depending on the TV size)
Next what type of antenna or cable (basic, digital) do you have and how is it connected to the TV? Is it an indoor or outdoor antenna and is it pointed at your area stations? See antennaweb.org or tvfool.com for details on where your local OTA stations are. (Note: antennaweb assumes an outdoor antenna but is very conservative in their list.) Antennas can be turned by the wind.
Do you have an amplifier or a splitter in the system?
First, remove the amplifier or splitter and try a direct connection to the TV. (I've had amplified splitters turn into signal filters after they failed. Then they gave no signal out from certain bands. Many areas only have UHF digital stations.)
Next check your cables for damage and try replacing cables. (I recently had a cable in the wall get damaged and had to rewire that outlet. The TV got good signal if I ran a direct line across the floor to another coax jack.) Alternatively, try connecting the TV to a different coax jack.
The final thing to check is the TV's inputs. They can fail. (I lost a few analog TV tuners to a lightning surge.)
I hope this helps.
Mar 08, 2012 | Televison & Video
How to connect an dvd to old tv
they make a small box called an RF modulator. It takes the audio/video signals and turns them into a signal the coax can read. You can pick one up at electronic stores. There usually about 15-25 $.
Feb 02, 2009 | Televison & Video
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
I have a Motorola Quasar TV and an outside UHF Antennae. I have coax coming from Ant. There are 3 coax connectors on the back and one pair of screw terminals for 300 ohm flat lead in cable that is...
You are losing a VERY small amount of signal using the transformer. It won't even be noticeable I'm sure if you switch to the coax in but the fewer connections you go through the less the chance of a bad connection. Use regular " Ant. In " coax connection or " RF in" whichever the wording is on the back of your set. Good Luck!
barneyluc
Oct 10, 2008 | Televison & Video
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
Hello,65613 mits
Good Day, boofis68;
Sound like you may have voltage concern,9 volt source. Check for 9-volts DC to the Terminal PCB at connector JA pins 57 and 58 if missing, check IC9C25 (9-volt regulator) part # 270P677030 on the Signal PCB and replace the two caps. Good Luck, big IRISH.
Aug 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My ilo has the built in atsc tuner
Try plugging in a powered antenna.
The DTV coax input is for over-the-air HDTV transmissions which vary depending on your location and surrounding buildings.  I have the LCT32HA36 hooked up to a powered antenna and it works fine, but it wouldn't work when I plugged in the cable from the wall.
Jan 22, 2008 | iLO LCT32HA36 Television
Mitsubishi VS-50707 50" Rear Projection Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
