Question about Dishwashers
I have kenwood dishwasher Kid 60b10 half way through cycle it starts beeping E1
5 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: e1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Posted on Sep 10, 2009
  • 16 Answers
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
Posted on Jan 24, 2010
mastatech
  • 478 Answers
SOURCE: E1 ALARM ON KENWOOD DISHWASHER
An E1 is a control board error. Sometimes it can be soldered at the heat element relay which get hot often and can melt the solder ion the board. It is fairly easy to replace a control board.
Posted on Feb 07, 2011
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
Posted on Jun 03, 2011
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Hi Kenwood dishwasher kdw60x10 - runs cycle then stops showing error E1 - still full of water.
May 14, 2011 | Dishwashers
Feb 07, 2011 | Kenwood KDW243A Builtin Dishwasher
Kenwood KDW12ST3A
E1 indicated long filling time. Perhaps the inlet filter has clogged. Check the inlet pipe and tap(faucet in usa).
Apr 16, 2009 | Kenmore 15762 Dishwasher
E1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
