Question about Optics
Canon binoculars 12x36 IS 5.6
Battery contacts have fallen out of the battery compartment and are lost. Canon can't replace. Have sent to Canon repair dept. and they returned it unfixed saying parts are no longer available.Any suggestions? Binoculars work well but stabilizer component does not.
  • 159 Answers
SOURCE: 12x36 only one eyepiece focus
Assuming you have already tried replacing the battery, contact Canon Service Dept.
Posted on Mar 22, 2008
  • 112 Answers
SOURCE: Our group has 2 pairs of Canon Image Stabilizer
when salt water gets in ..if its not cleaned soon then its probably to late...the cost of repair wuld be more than a new one...sorry...larry@reichinstruments.com
Posted on Aug 06, 2009
tbreeze47
  • 3083 Answers
SOURCE: My Canon 10x30 IS binocs got corrosion in the
You're going to have to ohm out or jumper the battery contacts inside the binoculars to see where you're getting a bad flow, and try to address that. Sometimes you can take a think piece of silver coated copper wire, or just copper wire, and make a new contact (solder the wire or glue it to the original contact).
It's really hard to find instructions, per se, for binoculars, since Canon's repair facilities are the guys that have them, but you can learn a lot from blogs about them, in general, and usually enough to get the job done. Just google "binocular repair", and you will find many.
I personally, would not coat the contacts with oil- that will just leave a barrier in the metal to metal contact that is essential in current transfer.
Here's Canon's binocular site, in case you decide to replace some parts:
http://usa.canon.com/cusa/consumer/products/binoculars
Good luck, and hope this helps.
Posted on Oct 08, 2010
ftw1952
  • 10319 Answers
SOURCE: The stabilizing motor on my
have the capacitor in the circiut board checked out for if faulty the unit will not operate. Capacitors are fairly cheap at Radio Shack stores
Posted on Oct 31, 2010
stonoga
SOURCE: I have Minolta Autofocus binoculars...8x22
Minolta AUTOFOCUS 8x22 BINOCULARS requires a 2CR5 battery to operate.
Posted on Feb 12, 2012
Need repair of Canon 15x45 IS binoculars
That is bad and I am surprised. Canon Canada is just down the street from me!
There are lots of binocular repairers here.
binoculars Google Search
Mar 06, 2017 | Zeiss Optics
The negative contact in the battery compartment has been severely corroded by a leaking battery. How can I open up the binoculars to get into the battery compartment?
Just a suggestion.. many battery companies warranty their batteries from damaging the devices in which they're installed due to leakage, etc.. I'm not familiar with your binoculars - but wonder if you can determine the battery manufacturer. If so, contact them and explain the situation and let them offer you a solution.
Aug 03, 2011 | Canon IS Binocular
I have a canon powershot A640 when you press the on button it wil
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Canon Cameras
How to restart canon ixus 70. Get an error message saying ''Lens Error. Restart camera.'' Lens won't extend.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon Cameras
Battery fully charged. but canon powershot sd600
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Canon PowerShot SD600 Digital Camera
My Canon A570is will not turn on
The problem that you describe may be due to corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Canon PowerShot A570 IS Digital Camera
Nov 18, 2007 | Canon (12x36) IS II Binocular
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
