Question about Refrigerators
Model RF 265ABWP
Hello my model # RF265ABWP Compresses Mk172D-R2U BDM Name RF 265ABWP/XAA Samsung RF265 series 26 cubic foot My refrigerator says its at 34 depresses but everything inside is very warm I would say like about 48 degresses and the freezes says -2 but the stuff like ice cream and French fries get thawed out and we have to throw out and it happens often can u please tell me what the problem is
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Posted on Sep 29, 2007
  • 161 Answers
SOURCE: GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Posted on Jul 03, 2008
  • 43501 Answers
SOURCE: refrigerator and freezer warming, usually 34, -4.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Posted on Jun 11, 2010
SOURCE: water build up underneath deli tray drawer
Ok. I know why this is happening. Or at least in my case.
The coil for the Fridge is stored behind the center panel when looking directly into the the Fridge.
What happens is the drain for the coil becomes iced up. It then wont drain and when the fridge goes into defrost mode the melted water will run out of the bottom of the center panel. This is difficult to see due to all the shelves in the way. i noticed this because I could see ice through the vent holes in my center panel.
To fix this:
Take all the items out of the fridge.
Take all the shelves out so the center panel is exposed.
Remove the 3 screws at the bottom of the panel and single screw under the cover of the shelf rail. (This one is a little hidden) pop off the plastic cover first.
Now you can pull the panel off.
(Note. This can be a little difficult to get off because you have a ton of ice behind there keeping it stuck to together. Just ease it off as much as possible.
When you get this off you'll most like see alot of ice in the tray that the water is draining into. chip this ice away and then I used Hot water to pour into the drain. I would then use a shop vac to **** the water out and put in more hot water until the ice plug is removed and the water can flow freely to the drain pan under the fridge.
That is it. I own this fridge and I've been tired of having to **** water out of fridge with a shop vac every 2 weeks. So I decided to resolve this myself.
*disclaimer. I'm just a DIYer not a Samsung repair person.
Good Luck and I hope this solves your issue.
Posted on Aug 25, 2012
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download. > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ... > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
What is the cubic foot size of this fridge...
If you put in the make and model of your refrigerator, it did not come through with your question. As far as sizing goes, most manufacturers will usually put part of the cubic foot size in the model number. For example, I just installed a refrigerator that at the store they labeled it as a 21.2 cubic foot refrigerator and the model # starts out as GTE21GS... That .2 cubic foot does not show up in the model but the 21 does, so that should give you a basic starting point. Hope this helps!
Aug 14, 2015 | Refrigerators
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
How size cu ft is it for tfx25zpbaww
Hello Edgar;
My name is Peter. I am a retired field service refrigeration technician.
The cubic foot is in your model number. In this case 25. Generally it is slightly larger 25.2 or so.
Dec 13, 2014 | Refrigerators
What is the cubic feet of my Kenmore side by side refrigerator model number 1068590214
The cubic foot of your unit is on a label in your fresh food section on the side wall near the top.
Dec 07, 2014 | Kenmore Refrigerators
How many cubic feet is a Frigidaire frt21tng 0
The cubic feet is in your model number. In your case it is a nominal 21 cubic feet. It can be 21.2 cubic feet.
Sep 04, 2014 | Frigidaire Refrigerators
Need a part number for start relay for Samsung Model RF265ABWP Refrigerator
go to this link and its item # 18-2 and should replace item# 18-3
***** scroll past item 18 with out the dash and you will see item 18-2 & 18-3 about 3/4 of the way down******
Jul 26, 2011 | Refrigerators
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
