Question about Refrigerators
Whirlpool ed5hhgxtq00 refrigerator
Frost build up on freezer rear wall, not making ice, and refrigerator section not staying cold? defrost timer or thermostat?
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
Amigaman
  • 248 Answers
SOURCE: Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Posted on Nov 14, 2007
  • 116 Answers
SOURCE: I have an Amana bottom
Typically with this model it is either the timer or the defrost thermostat.
This is behind the back wall of the freezer. It is attached in series with the element. It is designed to open when the heater gets hot enough. The part is about the size of a stack of 6 quarters and typically has a blue end coating on one end. The other end is silver in colour and should be clipped on the black coloured heating element. It will have 2 wires coming out of the blue end.
If this part is defective then it will have to be replaced. by cutting a splicing a new one in. Be sure to unplug the fridge before replacing it.
There are 3 main components that can give issues; the timer, the thermostat and the heater. All 3 should be checked to confirm the fault. NOTE the timer contacts can be burned out as they arc under normal operation.
If you have a multimeter then you can check if the heater circuit has 0 or close to 0 resistance when there is frost on the back wall of the freezer. if it is then the timer is bad.
Posted on Jul 28, 2008
SOURCE: Defrost problem on a LG Bottom Freezer Refrigerator
I had the same trouble. I found out if you have the digital display of temperature type of refrigerator adjust the freezer temperature to +5 degrees. The defrost systems uses a circuit board type. Not sure how it works. I took the back panel of and looked at the board. Did not see any manual defrost methods. I had to remove all the contents of the freezer and manually defrost. have not a problem since.
Posted on Nov 24, 2008
My whirlpool ed5fgexss00 wont get cold
Look at rear wall inside the back of the freezer and see if a frost line is building on rear wall. I have a feeling your freezer is not defrosting properly and not sure exactly what number you model has but checking the defrost timer Click Here=> ED5FTGXKQ00 Controls is where I would begin.We will need to run a couple test to make sure your=> 2323198 Heating Element and Defrost Thermostat=> 2321799 Defrost Thermostat are working properly.Testing heating element is also shown on same page above.Try turning the defrost timer clockwise slowly until refrigerator compressor stops running. This will place the freezer in manual defrost. Then tell me if once you do this if freezer begins defrost. If yes then the defrost timer=> 482493 Defrost Timer is at fault. If stays in defrost simply turn again until compressor restarts again. After doing this I will want you to watch this how to replace defrost heater=> Here I know this may be a little confusing but defrosting manually will help you see which parts may be needed. I will be here to answer any questions you may have, Thanks, Sea Breeze
Jan 08, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really...
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Mar 31, 2011 | Whirlpool Refrigerators
Refrigerator does not freeze enough
Lets have a look at rear wall of freezer, is there frost building up? Usually in top freezers the cold air settles to bottom and you don't notice fresh food section until about a day. If frost is building open fresh food sections door and in control panel=> CLICK HERE see item 257 in photo? That is WR9X565 or 311082 Defrost Timer Just below that is the control panel cover and you should have a small plastic plug covering a hole just below the defrost timer. Pry plastic plug out and using a flathead screwdriver turn the defrost timer clockwise slowly. Once you hear the compressor and fans stop stop turning timer and about a minute later you should hear some crackling noise coming from freezer. Allow to stay like that for up to 30 minutes and timer should come out of defrost and compressor and fans should start again on their own. If this action caused defrost then replace the defrost timer. If that does not seem to cause defrost the we need to go to step two, unplug and place items in a cooler or alternate refrigerator and use a hair dryer to assist in melting the ice behind rear panel. Remove rear panel in back of freezer and see => Freezer Components item's 621 and WR51X10038 or 880036 Defrost Heater Assembly
You will need to remove rear panel and work with refrigerator unplugged from power. On this=> Page watch how to test your defrost element just beside a photo of the timer. Most times I replace the defrost thermostat while inside freezer wall but I will let you try this first and please respond and rate, Thanks, Sea Breeze
Feb 13, 2011 | GE GTS22KBP Top Freezer Refrigerator
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
The freezer side is working but no cold temperature in the fridge section of our side by side door with water and ice dispenser kitchaid fridge. Wonder what the problem is?
Hi
If the refrigerator is in defrosting mode, the freezer compartment temperature will be less cold than usual. Wait 20 minutes, and you should be able to feel cold air blowing in the bottom of the compartment. If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will in turn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 19, 2010 | KitchenAid Refrigerators
My refrigerator is not blowing any air.
Sound like the beginning of a defrost problem. Look into the back of your freezer and see if there is a layer of frost building up on the rear wall. If yes you will need to unplug and remove the rear panel and defrost the evaporator with a hair dryer. After cleared of ice look over the defrost heater to see if burned out or if your defrost thermostat appears to bulge. Also send me the model number of your Whirlpool so I can see if it has a defrost timer or an Adaptive Defrost Control. That would be the most likely reason for the warming of the fresh food section unless the damper is shut to that side preventing air to circulate freely, Thanks, Sea Breeze
Aug 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
Freezer frosts up and then the refer doesn't get cold air. I have completely defrosted it twice. Model # ED25DSXDN03
You have either a bad defrost heater,defrost thermostat or defrost timer.
The defrost timer is located in the control panel box in the fresh food section. The heater and thermostat are in the freezer section behind the rear panel.
On this brand it is usually the defrost timer.
Jun 26, 2009 | Whirlpool Refrigerators
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
