Question about RCA 32V550T 32" TV
RCA television My TV continually runs the channels like some TV's do after a power failure.
    Genius:
  • 1,139 Answers
This might be a control processor problem you may have to get a schematic to see what the voltages should be as measured with a multimeter. I would say that this is a control processor problem.
Posted on Sep 19, 2007
SOURCE:
Model led42c45rq. Why won't it turn on?
An internal fuse may have opened or there could have been spontaneous power supply failure.
Jan 06, 2016 | RCA Televison & Video
How to hook up convertor to analog tv
It would really help to know what brand of converter (set top box) you are installing but I can provide some general information. Be sure to connect everything before applying power. On the rear of the box, you have two types of connectors. If your RCA TV is old, you can connect a cable from the ANTENNA OUT F connector to the antenna F connector on the rear of the TV. Connect an antenna to the ANTENNA IN F connector on the rear of the box. Set the box to send output to channel 3 or 4, whichever is not used in your area. Apply power to the TV and the box and tune the TV to the channel (3 or 4) you selected on the box. If your RCA TV is new enough to have inputs for left and right audio and video, you can connect a 3-conductor RCA cable between the appropriate outputs of the box and the corresponding inputs on your TV. The picture quality will be better the second way. Once you are up and running you can use the channel search feature of the remote for the box to locate HD channels
Feb 13, 2013 | RCA Televison & Video
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
AOC L24H898 LCD TV
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Apr 21, 2010 | AOC L24H898 24 in. LCD TV
Continues to channel surf wont stop on ant station
When i had the same issue, i used VCR or VCR Combo to set the channels,
May 14, 2009 | RCA R52WM24 52" HDTV Projection Television
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
look at the control board circuit -are there and signs of heat damage if so replace board
May 02, 2009 | RCA P52937 52" Rear Projection Television
Screen is blue no channels
if you can get pic using an external input you've got a tuning failure, if not video processing.
May 06, 2008 | RCA P46921 46" Rear Projection Television
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Getting the deleated channels back on my TV
it sound to be an eprom failure and thats nothing that you can do take the tv to a tech and pray for a cheap repair... good luck
Aug 06, 2006 | RCA 27F530T 27" TV
RCA 32V550T 32" TV Logo
29 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
