Oce 5150 how do i solve the media erroe?
Oce Colorwave 600ps errorcode 16702 what does it mean?
The media output sensor didn't detect the media in time.
Ensure that you are not pulling your plot out before the CW600 actually delivers it. The CW600 stops printing, cuts the plot, delivers it to the top delivery tray, but pauses for a second before fully delivering it to the tray. See if you get the same problem if you output to the rear. If this problem persists, please call an authorized Oce/Canon service representative.
Apr 06, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Need to reset unknown PIN on OCE 3165
There is a Ni-Cad battey on the logic board. You may be able to clear the settings by removing it for a few minutes. Then reinstall it.
Here is the user manual:
http://files.oceusa.com/media/Assets/PDFs/TSS/external/3155_3165/3165USER_v1_m56577569830529201.PDF
Aug 07, 2012 | OCE Office Equipment & Supplies
Oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Jul 26, 2011 | Office Equipment & Supplies
I have an error: "hardware error 0502" Can I fix this?
I have a Lexmark 5150
Hardware erro 0502 can I fix this
Sep 13, 2010 | Lexmark X5150 All-In-One InkJet Printer
OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Jul 13, 2009 | OCE Office Equipment & Supplies
Put wrong toner in machine now prints are black
There is only one way to solve the problem. Call a oce service rep. to come out and have them vac. out all of the wrong toner out of the hopper & developer unit and give the bill to the person that put the wrong toner in to begin with.. Good Luck...
May 27, 2009 | OCE Office Equipment & Supplies
Oce 3165 Copier makes black copy over text.
that is a very expensive and big machine. as an oce representative i suggest you call it in for service.
Oct 27, 2008 | OCE 3140 Copier
15 people viewed this question
jasbo
jasbo
