Question about Asko 24 in. 1585 Built-in Dishwasher
Asko 1585 Dishwasher
Dishwasher came with house and has been running very well up until 2 months ago. Upon completion of washing/drying cycle all the lights began to flash. Then we noticed that it was not even making it through to the wash cycle, it would fill sound like the wash was going on and drain then lights would flash and machine would stop running all together. We would hit rinse and hold and then the machine would run it's rinse and hold cycle until completed. Found there was a major recall on this model and just had the circuit board replaced today. Repair man left and went to run a normal wash cycle and about 10 minutes into the run the flashing lights appeared. I called ASKO and ran through 3 different tech who had me reset it, adjust the water intake and pump out timing and still the same - all lights flashing?? Any ideas?
  • ab11bc49 Jul 25, 2008
    My board was replaced about 3 months ago and I now have the same problem you describe. I called ASKO and they had no help. They told me that their is no way of telling if the problem is the replaced circuit board. They suggested that I call for service and pay someone to determine if that is the cause. I would like to know if other people are having problems with the circuit boards they used on the the recall repair.
  • Anonymous Mar 26, 2014
    My Asko d3122 dishwasher is stuck on rinse halfway through the cycle & I cannot reset it. As soon as I turn the machine back on the lights flash back to rinse also..
  • 175 Answers
Do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and...
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Sep 14, 2010 | Dishwashers
My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1796FI Built-in Dishwasher
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
Need the wash impeller for a asko 1585
TheySell complete pumps not separate impellars. sorry.
Feb 21, 2009 | Asko 1375 Dishwasher
ASKO dishwasher won't drain and makes rattling sound.
I had tried several failed attempts to fix this problem. Finally I got on my knees and asked God to make the dishwasher run in Christ's name. The dishwasher just completed it's first cycle without any problems.
Feb 10, 2009 | Asko 24 in. D3121XL Free-standing...
Dish washer
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
May 14, 2008 | EuroTech EWF150 Front Load Washer
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Wont dry
make sure you select a high temp wash and the heated dry as well Also, dont put too many plastic items in there at once, they dont dry very well in anything. Check the amount of soap you are using, it shouldent be more than 2 tablespoons (way less than the dispenser can hold in otherwords. lastly, make sure the weater coming into your dishwasher is may need to turn up your water heater or run the kitchen faucet hot water til its hot before turning on the dishwasher. you said the fan is working, so i assume you can feel the air flow out of it at the lower left during the dry cycle. if you open the unit after its been running for a half hour or so, see how hot it is inside. Idf its not steaming, you may have a bad heater. Thats all I can think of off the top of my head. Hope this help!
Aug 19, 2007 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwashers Logo
1,058 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
