Question about Music
Behringer DSP 8024 Firmware
I am in need of the EPROM with the last firmware revision released for this unit. It is one of the earlier, 2 rack space models, several years old. For the last few years I've used it simply as an RTA until it developed too many software glitches to serve in that capacity. I have been told by several sources, Behringer support included, that the latest firmware revision should be the cure for my ills. And have been told the chip can still be purchased. But I've yet to be informed as to where it might be purchased. I DO have a Windows compatible digital copy of the appropriate software but have been unable to locate anyone to flash it for me. I would gladly pay for the service if anyone could please tell me who might provide it. Or if anyone knows where I might find the OEM PROM, I would be exceeding grateful to anyone who could steer me in that direction.
  • 1138 Answers
SOURCE: i need to get step by step direction to set up a behringer cx 340
You will need to carefully read all your manuals and proceed step by step Here is the first one to look at:http://www.behringer.com/EN/Products/CX3400.aspx This crossover goes between the output of your board and the input of whatever power amps you are using. It has sections describing each setup and by what you have said, if you have enough amps you would probably need to run stereo 3 way which is described on pages 9,10 and 11. This would allow you to run a mono sub out setup. The grey areas are the connections and controls you use. Make absolutely sure your cables match the ones in the diagrams and read and heed carefully all the warnings. As far as your E.Q. and your Compressor they are separate topics as they are signal processors and are hooked up in the signal chain of your mixing board. They condition the input signals. Your crossover belongs in the output stage which as mentioned before is from the output of your board to the input of the crossover then from the outputs of your crossover to the inputs of your amplifiers and then on to your speaker systems. Try to find a friendly person on your end who does sound on a regular basis and has experience setting up and troubleshooting connection problems who wouldn't mind trading some advice for whatever help you could offer them. You have some good gear there and although there are people who will give Behringer gear a bad rap, I have never experienced any problems with mine. You absolutely have to understand all your gear inside out and not try to make it do something it is not designed to do. You also have to make sure you understand the differences between balanced and unbalanced cable connections and only use good quality cables designed for each application. If you're good at soldering and understand all the theory and want to do the work you can probably buy in bulk and customize everything to your own purpose. Enjoy your new equipment.
Posted on Aug 28, 2009
Testimonial: "good advice, will used them "
  • 5603 Answers
SOURCE: Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Posted on Dec 15, 2009
  • 5603 Answers
SOURCE: Setting up a Behringer PMP5000
You can do the effect via the "POWER AMP INSERT" jacks.
Use TRS interconnects to yout effects unit.
If the effects unit does not have TRS type bi-directional in/out ports, you MAY need to make special cables to connect the units. Refer to figure 4.5 on page 9 of your PMP5000 user manual for INSERT connections.
Posted on Jul 15, 2010
  • 5603 Answers
SOURCE: I purchased a used Hammond
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Posted on Nov 23, 2010
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
Factory reset
I don't think it's possible to reset a Faderport in the traditional sense since the firmware is not an EPROM (Electrostatic-Programmable-Read-Only-Memory).
I think it's more likely that the driver on your PC or Mac has become corrupted and needs to be uninstalled and reinstalled.
To do this, we'll need to know more about your platform, especially the DAW. Are you using Studio One v2 or v3?
Aug 04, 2014 | PreSonus Firestudio Project + Faderport +...
Behringer deq2496 displays firmware data not found / what do I do
Go to http://www.behringer.com and update new drivers and firmware. If you lack the Firmware, the system will not open or recognize the device at all. Check with their technical service and tell them to walk you through the process of installing the new firmware.
Dec 19, 2013 | Behringer Ultracurve Pro DEQ2496 Digital...
No effects output xenxy 1204fx
Likely needs the DSP board replaced. It is the small board held on by 2 screws(if I remember correctly) and is easily replaced. I think retail cost is about $30 and can be ordered directly from Behringer.
Aug 03, 2013 | Behringer Xenyx 1204fx
Behringer: EUROLIGHT LC2412 battery replacement
You need a CR2032 battery - get it from JayCar, RadioShack, whatever electronics store you have.
You have to turn the unit upside-down and take out all 11 screws from the bottom, and the two on the sides near the front. Then just lift the bottom panel from the rest of the unit.The battery is very obvious.
Behringer warn you NOT to do this and claim you could suffer an electric shock. I say, just don't touch anything you don't need to and you'll be fine. You might need to remove the rack-mounts from the sides of the unit if you have those.
behringer-eurolight-lc2412-battery-byrfig4kuyy51fmb23vlbqsc-2-1.jpg behringer-eurolight-lc2412-battery-byrfig4kuyy51fmb23vlbqsc-2-3.jpg
Jun 14, 2012 | Behringer Eurolight Lc2412 24channel...
Where can i get a behringer b2031a schematic
i found legit looking schematics here...the pdf includes many revisions, adding to their credibility...haven't put them to the test...
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,startdown/id,16026/
Feb 14, 2011 | Behringer B3031A 2-Way Active Studio...
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
Jul 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
An index of 1202 effects on mixer lost list
Most Behringer effects are done with the same DSP unit. If you can find the lst for one, it will likely be the same for your unit.
My PMP5000 has the list right on the face. I don't know how to capture the list but I might be able to photo it.
I have searched and it doesn't seem like there is any documentation readily available.
Mar 06, 2010 | Behringer Rx 1202fx 12 Channel Line and...
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
