Hello i was wondering if can recharge my challenge portable air conditioning unit af10000e
My challenge air conditioning unit is empty og gas and i was wondering if i can recharge it myself it is a challenge 10000e model number and i have bought the gas and the recharging gun but can't seem to find the connection on the unit can anybody please help, thank you
5 Suggested Answers
crouchdash
  • 83 Answers
SOURCE: Recharge air condition
if little air is coming out there maybe a problem in the blower or filters. But if there is air and its not that cold or warm then its a refrigerant problem or the lack of.
A simple check for lack of refrigerant would be to look at the refrigerant pipes on your rooftop unit and see if its freezing.
Altghough you can charge the unit by yourself, I would suggest to have it done by technicians because you would need to know how much refrigerant to put in there; what's the correct pressure; system integrity. You'll get your money's worth since it would not just be recharging but also system check.
I hope this helps.
Posted on May 27, 2009
koolbreezes
  • 540 Answers
SOURCE: locate manual for a challenge air conditioning unit
Check out fixya .com for a manual of your choie.
Posted on Dec 18, 2009
  • 1033 Answers
SOURCE: Air doesn't get cold like
Hello, yes the unit can be recharged but you need to install a piercing valve on tje low side of the system to charge in the refrigerant here is a link to where you can buy piercing valves. http://www.globalindustrial.com/g/hvac/parts/ac_accessories/Supco-Acces-Valves
Posted on Jun 07, 2011
Testimonial: "Thanks, this is very helpful."
wiccan8house
  • 48 Answers
SOURCE: I have a Challenge AF10000E portable air conditioning unit with a pipe that needs replacing but I have no idea how to find out what size it is or where to get it from. Any ideas?
Here is a link to a manual I uploaded for ya. It does show some pics, dimensions and local by country tel. numbers and e-mail addys to order from -- good luck and I hope it helps you out -- wicc --
http://www.mediafire.com/view/?uhmf4qec57e1zsq
Posted on Aug 16, 2012
Unit runs but will not cool. Followed troubleshooting diections in manual with no luck. Wondering if there is a refridgerant recharge path which is not in the manual
recharging with gas will not be in the manual as it is done using pressure gauges and is a job for an experienced refrigeration technician
call one in as it may not be a gas problem but compressor not running or a blocked tx valve
May 29, 2016 | Sharps 10,500 Btu Cv-2p10sc Portable Air...
I have just bought a secondhand challenge 414/0038 and I cant find where you empty the water when using dehumidifier?? As you can guess I didn`t get any instructions with it
There is a rubber bung on the bottom of the back of the unit. You remove this bung and water will drain out.
However you should read the manual because most of the humidity is supposed to come out of the exhaust with the hot air. I'm not sure how this works but it's in the manual
Please find the manual you need here:
http://www.stator.me.uk/414-0021.pdf
This covers 414/0038 and 414/0021 Air Conditioning units by Challenge
May 24, 2015 | Dehumidifiers
Aug 16, 2012 | Heating & Cooling
Need a manual for a challenge 414/0021 portable air con
Jul 26, 2012 | Heating & Cooling
NewAir AC-14000E not blowing ice cold air
Unfortunately there can be several reasons for your AC-14000E portable air conditioner not cooling well. As with most portable air conditioners the filter grates on the rear of the unit can be removed for cleaning. When those are removed you may be able to clean some portion of condenser coils. There is also the possibility that your portable AC has a refrigerant leak in the system and will not be able to cool effectively without a repair (which usually costs as much as a new portable AC). Portable AC's are not designed to be recharged and operate on a sealed refrigerant line so even finding someone able to repair it may be a challenge. Your best bet is contacting the company you bought it from and talking through some solutions, they most likely have experience with these units and should be able to help you.
Jul 10, 2012 | NewAir Heating & Cooling
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Locate manual for a challenge air conditioning unit
Dec 17, 2009 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
