Sony lcd tv problems volume 255 - Televison & Video
Sony Bravia tv, can't get sound out of wireless headphones with base station plugged in
Check the Volume on the TV, the audio jack is tied to the TV volume control.
Jan 09, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The volume is stuck on 255. I cannot turn the volume down from the tv or remote
Try to make factory reset. There is some step to do it. here added a link from which you can have the institution to do the factory rest. Go to the link and search wit the brand and model number and find the article.
http://electro-medical.blogspot.com/
Nov 21, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
Apr 08, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Sony KV-27HFR TV, no picture no sound; but got HV
The high voltage transformer may be the problem, because it feeds back secondary voltages to different parts of the set, for example is the vertical deflection voltage present at the ic, if memory serves me there should be around 26volts, if it's missing it means the fuse is open or the flyback pin is not generating the voltage.
Mar 07, 2012 | Sony Televison & Video
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
Jul 01, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
