Stereo ribbon cable connector
Where can I get a 13 pin ribbon cable connector that connects receiver to cdd on sony stereo LBT A37
SOURCE: Sanyo 8 pin din cable
from Sanyo LA,Calif
Posted on May 11, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
  • 1039 Answers
SOURCE: Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Posted on Apr 25, 2009
SOURCE: Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Posted on May 08, 2009
  • 4 Answers
SOURCE: Broken touchpad connector
I suggest you replace the motherboard. A recent search on ebay turned up three ranging in price from $18 to $85. Soldering a motherboard by hand has a very high failure rate. It's easy to bridge or scratch something and fry the board. You could of course try to do it and if it fails get a replacement board.
Posted on May 28, 2009
How should I hook this up to a Sony hi-fi stereo?
I would try going into the menu settings on your receiver to make sure that the subwoofer is turned on or that the volume is turned up. If it is a powered subwoofer you can try hooking the output of a phone or an iPod to the input cable just to test and see if you are getting sound through the subwoofer. If that seems to be working ok then you know the problem lies with the receiver.
Oct 09, 2015 | Sony Audio Players & Recorders
HOW DO I GET A MANUAL FOR A SONY LBT-A37
Google is your friend or contact Sony
Oct 07, 2014 | Audio Players & Recorders
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
How do I change the radio station and put it in the memory on a sony stereo unit LBT A37
Select the station you want, then pick a button you want to assign that station to and press and hold it until it tells you it has been set.
Aug 09, 2013 | Computers & Internet
Just replaced battery but dont know how to reattach ribbon cable on nuvi 200
flip locking flap on connector away from the gold pins. Slide the ribbon cable into the connector on the side with the gold pins as far as it will go. The ribbon goes face down with its gold pins facing down. Then using two fingers flip the locking flap down and toward the ribbon cable. It should click. Be careful, if you snap the flap it is game over.
Jul 31, 2013 | Garmin nuvi 200 Car GPS Receiver
I have a Sony cd player CDP-CE500. I have no knowledge of electronics. I tried to connect 2 computer-speakers with a y connector and mini-plug and it did;t work. Do I need a receiver and if so, I need...
HI,
If the computer speakers are a good one, then there is no need for a receiver. But there is one thing is the computer speaker have built in Amplifer. If not, you will not get sound. Because the audio out of CDP is not powerfull to drive a speaker directly. If so You need an amplifier between CDP and speakers.
Normally all computer speakers have stereo pins as input connector. To use this stereo connector with your CDP you need a
"2 RCA Male to 3.5mm Stereo Female Audio Adapter Cable". That I hve added in the picture. By the use of such a cable you will be able to connect the computer speaker to the female stereo and the RCA pins to your CDP. There is no othere settings needed. If the computer speakers is good then it should produce music.
If you need any more help fell free contact me through fixya or by mail at ajingopakumar@gmail.com
Dec 29, 2011 | Sony RCD-W500C 5-Disc CD Recorder
My Sony stereo receiver LBT-D159 is not working properly, does turn on, make a click sound when turn on volume, but get no sounds, also CD player does not recognize any disc
My audio in wont work when connected to my note note book pc,it worked fine about 2mons ago, ive even switched audio in cords and still nothing. Both my music on my pc and stereo wok seperatly but wont when connected HELP!!!
Nov 08, 2010 | Yamaha HTR-5930 Receiver
Good morning! I wish to plug our television into the LBT-ZX6 stereo, but the TV's output uses an optical audio cable. Is there an adapter of any sort that could convert the optical cable into the stereo...
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
Jan 25, 2010 | Sony LBT-ZX6 Shelf System
Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Dec 04, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
