Question about Garden
Troy bilt 13av60kg
What type oil do i use
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 37 Answers
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Posted on Jun 06, 2009
#1 Taper
  • 1041 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil does my Troy-Bilt 12a-264u011 5.5 HP walk behind mower use?
You can check your manual but i would use SAE 30, if in doubt call your Troy Bilt dealer
Jul 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Where is oil drain for honda engine on troy mower?
I don't believe Troy-Bilt is any different than other chainsaws. There is no drain plug. You just turn it over and pour it out through the filler cap.
I did look at a diagram for Troy-Bilt and there was no drain.
Hope this helps
Handie Andie
Mar 25, 2011 | Troy-Bilt Garden
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Transmission oil change.
"ue only G-L 4 gear oil having a viscosity of SAE 85W-140 or SAE 140"
Apr 21, 2009 | Troy-Bilt Chipper Shredder
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Spark plug
You can obtain a spark plug at any Troy Built dealer. Lowes is ours. Your owners manual should tell you what type of oil to use. Again you can obtain it at Lowes.
Sep 15, 2008 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
