Question about Whirlpool DWH B80
Manual Hi The power around my house was turned off , when back again the Dishwasher lights are off What do i need to do ? maybe reset ? Thanks
2 Suggested Answers
  • 189 Answers
SOURCE: Hi, the Council shut the water off to our house
Hello - Probably, but someone with basic electrical skills can check the wires in the power connection box under the unit. If these wires look good, the problem is best left to a pro. Some part of the circuit is grounding, causing breaker to trip. Finding out where is an on-site job. Let me know if this info helps- have more if needed. -Thanks- Ed
Posted on Mar 11, 2010
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
Aug 02, 2017 | GE 24 in. Profile PDW9800J Built-in...
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
The dishwasher starts and initially rinses the dishes without heated water. In the next part of the cycle, the water is supposed to heat to a certain temperature.Beginning this morning, in this second part...
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Dishwashers
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
We have a kitchenaide dishwasher and the clean light keeps blinking off and on and the dishwasher won't work. Of course it is Thanksgiving and I have a house full of people coming over! Any ideas?...
you can try to kill the power to dw and with 15 minutes before supplying power back and see if it will reset your control, if not you will need a new control board / thanks
Nov 27, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not working - Cancel light flashing
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Nov 27, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Whirlpool DWH B80 Logo
52 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
