Every time I turn my tablet off or leave the tablet alone (without touching it) for a few seconds this Samsung galaxy tablet 2 ad keeps repeating over and over until I shut down the device. How do I get rid of this annoying advertisement on my week old Samsung galaxy 7.0 tablet 2
SOURCE: Event repetition, as if key stuck
I think, you have a problem whit keyboard, may be Ctrl key is failed or is broken
SOURCE: My samsung Tablet is 10 wks old, a month after I
You should return the device. It sounds like a problem with the hardware or the software. A good many rooted versions of android exp. these same problems also.
Testimonial: "wow that was quick thanks."
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: Cannot send an email message on gmail from my Galaxy SII tablet
Try "Firefox" Mobile, sounds like browser/sync issues.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/keith_f374b1cfd1696a17
