Question about Utilitech 1-HP Lawn Pump UTP10P1
How to wire it from 110v to 220v...
Do you have a wiring diagram to wire pump for 220v.
    Problem Solver:
  • 12 Answers
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Posted on Jul 22, 2013
CAN I WIRE THIS PUMP TO RUN OFF 110 OR DOES IT ONLY USE 220
There should be a wiring diagram on the side of the motor. It will show wiring for 220V,or 110V, or both.
Jun 22, 2015 | Pool & Spa
Low voltage and hi voltage is just 220 and 110 can i still make the pump have two speeds
The 220v / 110v are the two wiring options on that motor. They usually come pre- wired for 220. The wiring can be changed to where it will run on 110. Be sure to get it right. if you wire a 110v motor to 220v it will go bang and die.
A two speed motor will have two hot wires, one common, and one ground (4 wires). Single speed will have three wires. You can't make a single speed motor a two speed motor.
Mar 01, 2015 | Pentair Pool & Spa
I have a 220V circuit (1 black wire, 1 white wire, and one green ground wire. The new stark industries pool pump has three terminals plus a ground, There is one terminal for a black wire (terminal A) and...
First, be absolutely sure that your motor is wired for 220v. If it is 110v and you apply 220v the motor will die instantly (after a loud bang). Also verify that your supply is in fact 220v.
Without exception 220v power should be supplied by two wires of the same color, as they are both "hot". Black and white wires are common in 110v wiring, the black being hot and the white neutral.
Every pool pump I have worked on has had two terminals where the wires attach to the motor, L1 and L2, wire orientation does not matter.
Evidently yours only has one. Apparently there is no wiring diagram on the side of the motor either, which is also atypical. Best bet is to call the factory for assistance with this.
Dec 22, 2013 | Pool & Spa
Pool pump not pumping
A few things to look at-
  • Did you fill the pump pot with water?
  • Check to make sure that the pot lid o-ring is in place.
  • Verify that your plumbing is sound and has no suction leak.
  • Check water level in pool.
  • Make sure the voltage is correct. Many pumps come pre-wired for 220v. If you have 110v supplying the motor it will run at half speed. There is a diagram on the side of the motor showing how to convert to 110V. Make sure that your supply is 110v before converting the motor. If you switch the motor to run on 110v and hook it up to 220v it will ruin the motor instantly.
Feb 19, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Wiring a AOSMITH S48A93A66 FAN MOTOR FOR 110
Motor wiring will appear on label on side of motor, for Lo 110V, and Hi 220V.
L1 is Line 1 is usually Hot wire
L2 is Line 2 is usually Neutral wire
Motor will show direction of rotation CW clockwise.
Compare diagram with old blower motor.
http://www.centuryelectricmotor.com/Applications/AdvanceCatalogSearch.aspx#Blower%20Units
Take photo of label and include link to photo so wiring diagram can be viewed.
Nov 08, 2012 | Pool & Spa
Does the pump come with the wiring set up for high voltage? I am referring to the brown and white internal wires. Pentair Challenger 346206. thank you
If you look at the wiring diagram on the motor plate it will show you where these wires go for 220v power, and where they go for 110v Power. If you know the supply voltage just place these wires as shown on the diagram and you should be fine.
Sep 17, 2011 | Pentair Challenger High Pressure Pool Pump...
Mdl.919.165250need to change wiring from 110v to220vshow wiring diagram for compresor
Your compressor was made by Porter Cable for Sears. The motor / pump is used on many different compressor models depending on tank size and style options. None of the models /including yours/ were ever designed for 115/220v. I did happen to see a compressor that was built for european destination that was 220v. It was easy to identify because it had a two round prong male plug (it could not be wired for 115v however). Good Luck
Jan 29, 2011 | Craftsman Air Tools & Compressors
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Utilitech 1-HP Lawn Pump UTP10P1 Logo
217 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
