Question about Freezers
3.0 where is #1#4 cylinders - Freezers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
The cylinders in what?
Posted on Jul 21, 2013
My landrover freelander is smoking after changing cylinder head and timing belt
IF you changed one head for another I suspect valve stem seals may be at fault on the other head. This is revealed by allowing the engine to idle for a while -say 3 minutes -then reving the engine to see if there is a cloud of smoke from the exhaust.
Sep 06, 2013 | Freezers
Good morning, please i change my timing belt and cylinder head, now my engine is smoking blue heavily and it can not speed up like before, once i put on the a/c it will off the engine and begin overheaten....
hav the headbolts retorqued--if not rite the head will warp--a bad gasket can cause coolant to penetrate to the cylinder too--oil is gittn in also maybe from bad vajveguides
How to fix a Kenmore chest freezer model #255.19502010
Kenmore model 255.19502010 seems to have this problem where it will not get cold anymore, but it is a $12 solution and and easy wiring job. Easy like if you know colors and how to plug things in you should be able to do it. Get a Supco 3 n'1 Start (model RCO410) for a 1/4-1/3 hp compressor on ebay or Amazon. This one device replaces 3 different components (relay, overload and start capacitor) that all have a tendency to fail. When it arrives, make sure the frezer is unplugged, remove the metal panel on the side of the freezer. You will see a large black orb almost the size of a football, that is the compressor. On the left side there is a black plastic box that covers the connections on the side of the compressor. Open that up and you will find another black plastic thing plugged into the compressor that has a bunck of wires plugged into it. Pull it loose of the compressor by pulling straight back or gently prying it away with a flat screwdriver. You will see that it is plugged into 3 metal prongs that stick out of the compressor. You will see that all the wires go back to a Cylinder shaped device about 1.5 inch diameter and about 5 inches high it is secured to the bottom rail with a single bolt. Remove the black cylinder and all other pieces that were plugged into the compressor. You should be left with a white and black wire coming from the dial selector on the front. Follow the directions on the package of the SupcoBy connecting the white wire to the lower left prong on the compressor, the Black wire to the top center prong and the red wire to the bottom right prong. Connect the other 2 black wires to the black and white wire coming from the dial with the enclosed wire nuts. Put the new 3 in 1 next to the compressor andplug in your freezer to test. If it gets cold then unplug it and secure the new 3 n1 with a ziptie, duct tape' screw' or some other way (do NOT screw into the 3 n 1 just through the hole in the top.)
If this does not fix your freezer then put it on craigslist for a fermentation chamber for home-brewers and home wine makers because your compressor is probably shot.
One note: while I was repairing mine I took the dial thermostat out and int eh process unplugged one of the connection. The first time I plugged in my freezer it did not turn on but the green light was on. If this happens to you inspect all the connections and make sure they are on tight.
Feb 07, 2013 | Kenmore 5 cu. ft. / 142 liter Chest...
Beater stuck in Taylor Ice Cream Machine Model Number 168-27
these units are usually set up to have the beater rotate in a clockwise direction facing front. If they get stuck, it is usually due to excessive wear or the hexed end has been lubed and has created a suction seal in it's counter part. Try rotating the beater in a counter clockwise direction while holding the drive wheel pulley stationary. Be sure to unplug unit first. this has worked for me in the past but can be very difficult at times.
Feb 18, 2010 | Freezers
Freezer temp
Was the condenser fan back there running. It should be when the compressor is.
Is the fan in the freezer running. Check for ice buildup on the back wall and behind the back wall cover on the evaporator coil. Heavy ice here would be defrost problem.
Jul 12, 2009 | Freezers
Freezer not working, odd rythmic noise.
Is this the capacitor wires you are asking about perhaps?
Sep 08, 2006 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Freezers Logo
16 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
